MicroReel Came Today....
  • MicroReel Came Today....
    Just like Christmas around here today
    65' MicroDrain drum should be here shortly.
    Gotta go play now..............
    Re: MicroReel Came Today....
    I see you are doing your part to help spur this economy
    You are going to LOVE that setup!
      Let me know how you like it. Been getting a few calls for small drain inspections.
      Rod
      http://unclognh.com
        Sexy looking tools.... I need to stop looking at so much plumber porn. Makes me want to go out and buy something.
        Ideal Plumbing
          That is a sweet unit. I will be looking forward to your review of it.
            Your lights are gonna' go out on the MicroExplorer and nobody can tell you why.
              Feels good to invest in your business with things that make you money. I have not purchased a camera and locator but the need is growing....mostly the locator. I'm thinking of getting a sonde that attachs to a drain cable and buy a scout locator. Glad to see you got it.
                I went that route and while it's made me money, I wished I'd bought a camera back then. With the sonde you have to make assumptions of what it's doing in the pipe. Your assumptions may not always be correct.
                www.ClinkscalesSeptic.com
                  I hope this link works but go here to regester yor micro real and explorer and you will get a free extra battery for the explorer
                  http://www.ridgid.com/RIDGIDToolBoxC...Type=microReel
                  SMELLS LIKE $$$$$$ TO ME
                    I only new about that cause Josh gave me that link and I did get the free battery took a month befor it came in but I got it beets buying one for $100.00 or more
                      What are you talking about making assumptions? I talking about screwing the sonde on a drain cable...sending it down the line and then locating it in the front yard etc etc so i can dig it up and install a cleanout. It should get me over the sonde and tell me how deep it is.
                        yes it will. but it will not tell you what's wrong with the pipe or if the line is clean.
                        i have at least 6 different sondes and carriers for them. ever since buying a camera about 15 years ago, i can't remember the last time i used a sonde. even if it's just for a locate the line call.
                        the camera and sonde combination is a win, win deal.
                        anyone interested in sondes and carriers, i can make you a deal even on locators some new
                        rick / ridgid close enough
                          I already know whats wrong with the lines....its the 500 oak trees and clay pipe with cement joints. I just want to locate the sewer without using a probe. Some places the grounds hard or there are alot of undergrounds.
                          Plus if I ever do buy a camera i will have the locator.....so I'm only out the cost of the screw on sonde...big deal.
                            Rick I agree with you 100%, ever since we got our camera system 17+ years ago we hardly use the sondes that attach to the rods. Even for simple locates we use the camera.
                            Its nice to be able to see the exact problem area and pinpoint it with the built in sonde.
                              most of the time doing what I do..(very little drain cleaning) I'm just trying to locate lines to replace them or make a connection from a bath addition. A camera for me would be a toy most of the time. I dont particulary enjoy sewer work,I've done my share and I dont hafta do it anymore. replacing line or adding a cleanout,making the addition connection is all I'm really looking for. And as I said I already know whats wrong with the sewer most of the time,bad joints cracks and roots in 60 yr old clay sewers...no mystery there.
