Code change
  • Code change
    I believe any over head cleanouts should have a built in 1" or bigger full port valve built into the cover. I don't care about any hocus pocus ways we handle over head C/O. what is needed is a controlable way to drain a full system. PERIOD
    Re: Code change
    I say all overhead sewers should have a outside clean out.
      Re: Code change
      See the problem is that makes to much sense...so you know that won't happen...as we all know code book is minimums...
      Derek
        Re: Code change
        did u get a bath ?
        Sent From The StoolBus
        www.appletondrainandsewer.com
        Appleton WI, 54915
        1-920-284-7471
          Re: Code change
          We dont have very many basements hear but i can imagine the problem with a clean out above my head
          I have never /almost never gone under to clear a drain
          I always dig up out side it not deep down here
            Re: Code change
            Probably a shower!
            Seattle Drain Service
              Re: Code change
              Originally posted by appletondrain View Post
              did u get a bath ?
              man oh boy howdy. it was not pretty. i thought I had it under control, NOPE. I haven't had one get away from me like that in a long time.
                Re: Code change
                You are lucky we have a bunch. I was a mess
                  Re: Code change
                  In certain areas here when there is a hung sewer there must be a cleanout that extends outside the house with an accessible cleanout ..One inspector require a cast iron panella cap with raised head plug..Yep..In my opinion a good idea, that way if the system backs up pop the plug outside and snake all the way to the street , tank, etc.
                    Re: Code change
                      Re: Code change
                      I never had to go through an over-head clean-out in a basement, and 98% of my area has basements. Most of the new homes in my area have 10' ceilings or slightly higher...I'm pulling a trap or toilet first before I would think about hitting the "over-head" clean-out in the basement.
                      But I hear what you're saying.
                        Re: Code change
                        I know I would never pull an overhead cleanout..I don't even know why they are code to install in certain areas..They are not readily accessible if you need an 8' ladder and have to remove ceiling to get to em'..Most get covered up anyhow
                          Re: Code change
                          Drill and drain.
                            Re: Code change
                            Drill and drain.
                            Only if it's a last resort
                              Re: Code change
                              Or you can do this!
