Reattach cable in Rigid hand crank snake
  • Reattach cable in Rigid hand crank snake
    Hi -
    i have a Rigid hand crank snake. Somehow the cable became disconnected from the crank. I took off the handle and did not see an evident way that the cable was attached. The cable has a flared spring end with a bit of orange plastic sticking out. The handle has a bolt with a spring on it, pushing against a c shaped clip that is facing back towards the handle.
    I can post a picture if it helps. If anyone had a clue how this thing was connected, I would really appreciate the pointer.
    Thanks
    Bill
    PS Actually, I have a camera handy, it seems easy to post a pic, and it might help with this odd little connection problem
