Alternative Sewer Machine
  • #31
    Re: Alternative Sewer Machine
    Yes. I use the General I95. Works fine for me.
    I've never used a K-60. I think it spins alot faster and is probably a little stronger.
    Other than that, they pretty much have the same operation.
    Okay so here we go: How is the ease and cost of maintenance? What cables do you use? Looks like a Ridgid cutters would interchange ...true? Whats longest and biggest line you ran it? I only ask because I have looked back into the forum to accumulate data on the k-60 from users...so guess what? Your the man to put forth the information on the I95...if you don't mind that is...and have you ever ran a drum machine by chance? Any thing else you could tell me about this would be great...thanks!
    Derek
    • #32
      I had looked at buying the general i-95 back before Rick turned k-60 crazy lol, I didn't buy it for one reason the motor was smaller and I know roots! If I was looking for something smaller I would just buy the K-50 even though it looks like the i-95 falls between the k-60 and the k-50. Plus the general forum sucks... oh wait they don't have one.
      Seattle Drain Service
      • #33
        I wouldn't consider me "the man" on any plumbing subject.
        Maintenance? I don't do much of anything to it. Grease fitting on top to hit with a shot once in a while. Little penetrating oil when I feel like it.
        But we rarely see roots here and I don't do as many drains as others do.
        Cables are about the same. General cables are said to be better.
        Longest run? Can't remember. Maybe 90'. Not too impressive.
        General does not have a forum. I did email them awhile back and received a correct response the next day.
        Heavier user, 4" lines, roots.....I would recommend someone get a K-60 or comparable Rothenberger but use General cables. I wouldn't be afraid of a Rothenberger either with the right deal. Some would because of the smaller market and support.
        • #34
          Well that's cool...it sounds like k-60 might be the way... most sewers I do are 4" with heavy roots up to average 90 - 100 feet...but still gathering data!!!
          Derek
          • #35
            k-60 would be a perfect choice.
            the 1.25'' x 10' sections and timberwolf would be a heavy overkill unless you get into nast roots and 6'' lines.
            i have the k-60's , timebewolf, i95 and root 66 to name a few
            the k-60 is the machine that gets used on 90% of the jobs i do.
            the root 66 is similar to the k-60, but has little to no support from general or it's distributors.
            get the k-60 and you'll thank us later
            • #36
              I've been looking at the root66 and i95 myself. I probably can find one cheaper than a k-60
              • #37
                The K-60 is superior to the RT-66 in every way. Well worth the extra few $$ vs the general machine. Parts are way easier to come by. The I-95 is more comparable to the K-50 if you look at the specs (even though the I-95 looks more like the K-60 than the K-50)
                • #38
                  Ditto. If you're doing 4", the K-60 is the easy choice from the Ridgid line up. Get 1 section of innercore for the lead cable on really nasty roots and use the hollow core on the rest (much much lighter). The spiral root saw blades are a must too.
                  • #39
                    What drum machine(s) are you running now?
                    • #40
                      Yeah I know the K60 is better. We have a k750 that we use for mainlines. We do come across drains that we have to clear through the roof vent that a k60 or root 66 would come in handy for. Where I am most of the laterals are 4 inch and rarely over 80 to 100 feet so a root66 would do the job just as well as a k60 in my situation.
                      • #41
                        k-60. all 4" or smaller. 130' on 2 occasions. almost all roots blockages. + ricksters patented, world famous reverse auger. to be honest if i had any other sectional machine i would make one for it, also. breid.................
                        • #42
                          Sewers K-7500 with general wire 3/4" smaller drains K-400 with 3/8" ridgid cable then for urinals and lavatory sinks I use the autospin but soon that will be upgraded to K-40....
                          Derek
                          • #43
                            You said the Root 66 is similar...if support wasn't a problem how would you feel about...now please be honest...and have you used the root 66?
                            Derek
                            • #44
                              used it i own it
                              the root 66 is actually not bad. instead of an adjustable clutch, they use an adjustable arm to engage the clutch. i rarely use the guide hose on my machines. but the root 66 has a swivel guide hose. which i feel i s a bonus.
                              the machine uses the same ridgid ends and they interchange with the cutters and cable.
                              i use it as a backup machine or when i have a second set of dirty hands
                              have not needed to tear into the machine as i use it maybe once to twice a year. i would be afraid if i broke it, there would be an issue to get parts.
                              the k-60 is easy to maintain and as i've said, i'm still using the machine i bought used from a rental co. and it's still going strong after over 1000 uses in my possession. 1 clutch and a couple bearings later. i think i've chopped down an entire ficus tree with that machine.
                              • #45
                                used it i own it
                                Thanks so much for your and everyone elses input....just one last volley of questions...this will theoretically be a secondary machine used once or twice a week...what size cable, style, and cutter selection do you and you other sectional machine guys suggest....and any thing else I should know? I only ask because some of the sectional information on past posts has been a bit confusing for me...not ever used a sectional...thanks again!!
                                Derek
