To much for the K60
  • To much for the K60
    Gave the K60 a good test today heavy roots "frozen roots" that is.
    Did not know the roots were frozen till I hit them. So the K60 had to sit it out and let big brother finish the job.
    Tight squeeze in a basement full of junk tuff to work in. Frozen roots were no match for the drill and eel.
    Drill and eel and K60 make a good team
    Rod
    http://unclognh.com
    Re: To much for the K60
    I've complained about cold weather this year. But I've got no right to complain.
    Man, you've got frozen roots.
    Sidenote: Anybody else ride one of them exercise balls around at a party like in Pic. 1? Just me, right?
      Place was such a mess up stairs too. I was getting mad had to move the dryer and put it back to access the sewer. I just wanted to kick that thing and eveything else too. No matter where I put it It just kept falling back in the way
      Rod
      http://unclognh.com
        Frozen roots and frozen sewers. Can that ell and drill set up go thru both? If not do you jet?
          If the freeze up is to big you need to jet if the roots are frozen in a section or sections no drill and eel will take care of it.
          Rod
          http://unclognh.com
            Due to ledge in the area our sewers can be 12 feet deep or as little as 3 feet deep. Septics can be 2 feet or less. When it gets cold the shallow sewers freeze easy and form root icicles
            Rod
            http://unclognh.com
                  Originally posted by AssTyme View Post
                  Not much stops the drill and eel. I service this ladies sewer every year around this time sometimes its frozen somtimes its not.
                  Clay pipe roots at every joint she does not want to replace the sewer
                  Thought this would be a good test. Sometimes you just need big brother to win the fight
                  Rod
                  http://unclognh.com
                    Man that k-60 looks really clean!! Too clean, you need to use it more!
                    like i say, the k-60 does 80% of my drain work! The eel does the other 20%
                      The word your looking for is HOARDERS...they even have a t.v. show about them...worse than object hoarders are PET HOARDERS...I don't even want to start on that shiz nit!!
                      Derek
                        [QUOTE=dcman;332020]The word your looking for is HOARDERS...they even have a t.v. show about them...worse than object hoarders are PET HOARDERS...I don't even want to start on that shiz nit!![/QUOTE
                        she was definitely a hoarder with a case of crazy cat lady syndrome
                        Rod
                        http://unclognh.com
