Tight SQUEEZE!
  • Tight SQUEEZE!
    Swear they built this house around the oil tank now way to get it in or out!
    I don't know how I fit in there?? I'm a big guy too. K60 would have been no help to me because both me and the K60 are not going to fit Got in there with the drill and eel.
    Had to move a stack able washer dryer remove an adjustable metal support beam Squeeze behind a 330 gallon oil tank and the foundation and knock off a lead fit all. Dude I don't know how I did it. Drill and eel saved the day.
    Door to basement and stairs no way my drum machine was going down there.
    Rod
    http://unclognh.com
    Re: Tight SQUEEZE!
    I like Your set up. Are You and Rick the only Two using drill motors and sectionals on the forum, You Guess ???
      Re: Tight SQUEEZE!
      Gene uses it too. I hear there are others and some companies doing it also. It's been my ace for 16 years. Today was a So glad I had this moment
      Rod
      http://unclognh.com
        Re: Tight SQUEEZE!
        i know how it is when you cant fit into a spot im 6' 4" and 280 lbs
          Re: Tight SQUEEZE!
          Good thing I did not stop for lunch before this call
          Rod
          http://unclognh.com
            Re: Tight SQUEEZE!
            Hey Rod here's one for the drums...cable was about 2-4 inches in front of my face...
            Derek
              Re: Tight SQUEEZE!
              Drum would have been my choice there also
              Rod
              http://unclognh.com
                Re: Tight SQUEEZE!
                I will say this..can a sectional machine be ran on its back?? Whatcha think?
                Derek
                  Re: Tight SQUEEZE!
                  Well maybe If I bought the eel 5/8 cable and adaptor for the drill it could have been done PITA but would work. I take it the sinks were loaded to the brim. Would have done the same or went on the roof with my DM-138
                  Rod
                  http://unclognh.com
                    Re: Tight SQUEEZE!
                    sinks were full and the blockage was at the tee in the wall... crammed full of tomatoes....couldn't go through roof for two reasons, one the plumbing is re-vented to much...the roof was only accessable from a inside hatch via a straight up ladder...
                    Derek
                      Re: Tight SQUEEZE!
                      I hate that climb up there for nothing So much for that strait shot to the blockage.
                      Wish I had someone with me to take pictures. Kitchen sink clog. Sink was loaded 2nd floor bathroom window just to the right of the window was the vent for the sink Reached out the window about 2 feet to the right used my supervee and cleared it from there. Did that one about 2 years ago I want them to call back so I can do it again as long as it's no 40 below zero lol.
                      Rod
                      http://unclognh.com
                        Re: Tight SQUEEZE!
                        Hope that job came with hazardous pay...did u ever get that video of u and the timberwolf?
                        Derek
                          Re: Tight SQUEEZE!
                          on jobs that are way above ground, i just strap my k-60 to the top of the ladder or my little giant work platform.
                          the machine with a ratchet strap is then only a foot or 2 from my c/o opening.
                          i'm sure i have photos of it posted, on some thread, but it's too late for me to search for them.
                            Re: Tight SQUEEZE!
                            Have the video done just need to find out how to upload it. Giving me trouble need a WiFi spot to up load video from phone
                            Rod
                            http://unclognh.com
                              Re: Tight SQUEEZE!
                              next time you're near a hospital try using their wifi.
                              when joey was having phoebe, their upload speed was faster than their download. and 5 times faster than home
                              not sure if you have access or not.
