wrong way to clear a trap.
  • wrong way to clear a trap.
    When you're hired to clean a floor drain. Poking a hole in the bottom with a drop head is not the best way to get the water to drain. Cause then you have to bust a hole in something else.... the concrete floor.
    Re: wrong way to clear a trap.
    Damn it...I hate when that happens...you follow me around eh? Looks like a nice straight forward repair....made you need to WD40 that chain cutter...HA!
    Derek
      Geno, Ran into this at a Shaw's supermarket no basement all slab. When I moved to this area they had no real drain cleaning companies. Shaw's tried plumbers they could not clear it. Then maintenance tried again gave up and drilled holes in the bottom of the traps just to get them running
      They called me a few years later to try after the ground would not accept the water anymore used shop vac and found their maintenance handy work.
      Rod
      http://unclognh.com
        Can You explain why the snap cutter and busted concrete ?
        Am I the only one doing this in 3 "
          I ran a drop head on a 3/8" cable through the bottom of the trap in a 2" cast iron floor drain. At this point I felt the responsible thing to do was to replace the floor drain so the concrete around it just had to go.
          The snappers was to snap the cast iron between the hub and the trap. I had planned on cleaning out the hub and using a push gasket but the cut ended up being so clean I was able to use a mission coupling with the new trap.
          Whatever was plugging the old trap was like cement. It took a hammer and chisel to put a dent in it after I busted the old trap up.
            You just proved what a good job Mom and dad did with You !
