And the golden ficus award goes to ?
  • And the golden ficus award goes to ?
    Over the years i keep hearing Rick mention these roots and blockages. He and others must have made a ton of $$ on these
    wonderful trees. It would be fun to have a trophy similar to these Knarly roots and give it out once a year an one of Your get to geather
    events or dinners. Any one care to add to this idea ?
    Re: And the golden ficus award goes to ?
    seeing that mark doesn't do drain cleaning anymore, he's not up for the running. that leaves adam up against me
    problem is adam never does the competitive thing. 2 roundups and he was an onlooker maybe it's more fun to watch than to compete
    i always like to offer my catch of the day to the owner for root soup.
    street of large ficus that i routinely snake.
    some ficus roots, soup anyone?
      Its magnolia tree,live oak trees and pine tree roots here that cause most of the trouble.
      The severity are in that order but most of the time its live oak tree roots. pine roots are the easiest.
        Silver Maples and an occational Weeping Willow here. Pine roots don't even get deep enough to find sewers.
          lots of oaks even more sweetgum trees...damn prickly balls!!
          Derek
            Yes down south the sewers are not that deep typically. I find then from right on top of the ground at the house to about 8' deep at the curb. There are deeper ones but thats the typical. Shallow
              How did you get that cable out of that sectional machine with all those roots on it?
                Fire pit
                  pretty simple. either disconnect the cable and remove it from the other end of the machine. or spend a minute with a little pruning shear or linoleum knife to easily cut them free.
                  if it's really nasty, and i'm in a hurry. disconnect the cable and replace the 1 section with a new cable. the cutter unlocks in a second.
                  wet roots are easier to cut than when they dry out in the truck.
                    So in that pic you pulled the cable out of the drain and then pulled the cable out the front of the machine and left the roots intact on the cable.
                      WOW!
                      I really need to get a ficus seedling so I can figure out a way to make a Ficus and Pine hybrid that thrives in a cold weather environment.
                      I could make some pretty good coin just selling them as an exotic tree, but a few years later I'd make millions when the crazy hyper roots take over
                        How about a hybrid Willow Ficus tree a "WilloCus"
                        Rod
                        http://unclognh.com
                          I can't get over how nasty those roots look to be.
                            This is 18 feet total. If I remember right the longest intact was 10 feet.
                              [ATTACH]12875[/ATTACH]
                              [ATTACH]12876[/ATTACH]
                              Root like that had to come outta Chalmette In the freeze of 89 I worked for 2-3 weeks over on Gov. Nichols St. and all through the Garden District. Oh how I love Dem Saints.
