Today's 200 foot run Good day to own a drum
  • Today's 200 foot run Good day to own a drum
    This is why it's still good to carry a drum machine
    Well, they called this morning about that 200 foot sewer run I posted on another thread yesterday. Line runs threw a small forest of trees 200 feet to a manhole on the street below. Pull up to look up the hill to see the grade and the lay of the land and there is raw sewage coming up out of the ground about 170 feet down. Picture 1 shows the awesome "Sludge Slide" Last picture is the nice view I had while running this 200 foot sewer also 60 degree's out today. Loaded with roots at every section of clay took 6 hours to remove the roots. Only took one photo of roots they were all about the same size coming out.
    Nice view's but then 4 family home was a DUMP!
    Customer turned down using the camera Had the city come out open thier manhole and we dye tested from building to test flow.
    Rod
    http://unclognh.com
    Re: Today's 200 foot run Good day to own a drum
    eeewwww!!!! nasty....nice though....good job...sewer gods would be proud!!!
    Derek
      What's that in pic. 3?
        Just the average size clumps of roots I was pulling out per section of clay pipe. They were not too tuff just a lot of them.
        Rod
        http://unclognh.com
          No, I mean the white thing. I've never seen an accessible cleanout here.
            Trust me This one was extremly rare for me also lol. Lucky it was sunny and 60 degrees too and not -20 or something
            Rod
            http://unclognh.com
              You probably had your shorts on compared to what your used too!
              Good to have several machines & equipment. It would have sucked to run a K-60 there.
                Did you pack a lunch
                  I pack my luch all the time called my big fat spare tire lol.
                  Job was only 8 minutes from home
                  Rod
                  http://unclognh.com
                    I was going to say the same thing! I've seen one of those once.
                    Outside cleanout, 60*.
                    Must have felt like heaven
                    Oh your going to pay for this one Rod. You know it comes back three fold right?
                    Next week you'll be posting; 5* below zero, clean out in crawl space 50' away and home owner is a cat person with 25 cats.
                      I don't know Gene? Hope I already paid for this one with the two slip and falls this week. Today 60 tomorrow 0 lol. This will help drive the frost down
                      Rod
                      http://unclognh.com
                        Not to mention 6 flipping hours...even on a drum machine that sucks!!
                        Derek
                          Made a few bucks off that one At least they don't have to dig. think of the Thousands it would have cost to replace that sewer
                          Rod
                          http://unclognh.com
                            I know it works both ways... good money but crappy way to get it....(no pun intended)...
                            Derek
                              Best part it was 8 minutes from my house I like these type of jobs beats 6 hours of windshied time. If it was freezing out It would have sucked.
                              Rod
                              http://unclognh.com
