The K60 worked today and a back saver this winter
  • The K60 worked today and a back saver this winter
    After yesterdays 200 foot run and then 4 hours with the city at the local hockey rink. Got three calls all before 7:10 Am. I'm never this busy around here. K60 made my day easier One call I had to lug the K60 out back of a customers house to the septic tank lid in three feet of snow! then a tight Laundry room the other a basement with tuff access.
    Last year I would have been pooped K60 made today easier.
    Rod
    http://unclognh.com
    Re: The K60 worked today and a back saver this winter
    Damn it Rod...your gonna make me have to go buy a K-60....
    Derek
      Don't forget the drill and eel too Having all three has made life so much easier. K60 has been a good little helper.
      Rod
      http://unclognh.com
        Gotta tell ya the drill scares the sh*t outta of me!!!! The K-60 would be a supplemental machine...just waiting on a good deal...plus getting my camera fixed first....
        Derek
          Thats what I did too waited and waited for a deal.
          Would love a nice big jetter only problem it would only get used once every three years or so. Would never make money with it here.
          Rod
          http://unclognh.com
            Same here...I have a cart jetter that I use about 5-6 times a year.... big one would be cool but...have a lead on a used K-60 for 650.00 but don't know if its a old style or new style...apparently old style doesn't use and can't use a guide hose...??? so i got to wait to find out which....
            Derek
              Get the new style From what I hear parts are more common and it's easier to fix. You don't see Rick using a suit case style
              Rod
              http://unclognh.com
                Rod, what were you cabling in the septic tank? The line going towards the house frozen? Curiosity sank in right before I got chills thinking about all that snow. Guess it's easier to carry the K60 than roll the 7500 in the snow..
                  actually i would go old school if i found a good unit. had a chance to buy a new old stock one, but it was priced like a new, new stock unit. i passed.
                  with the fiberglass sides, i think i would ruin it in the first week dragging it around.
                    K-60............ Baaaah..........
                      The home owner replaced a section of sewer last year 30 feet from the tank line is sagged. All plumbing fixtures were on an upper level clean out was in a closet on lower level tubs and toilets holding water Clean out just over all his water softer and tank electric etc. Would have been a mess of epic pre portions. Owner had septic cover already pulled
                      This was the best and cleanest way
                      Rod
                      http://unclognh.com
