The K-3800 saved the day.
  • The K-3800 saved the day.
    Not much talk about this great machine. Had a nasty back to back bathroom sink stoppage. Tried my top snake with the 5/16 spring head, a couple of straight 5/16 cables with the ends cut off, which is my go to cable and always gets those bad, back to back sinks cleared. Nope. Then tried the K-60 with the 5/8 cable and several cutters and still couldn't clear the line.
    After two hours, I bust out the K-3800 with the 13/32 cable(tight fit through the door though) with a half cutter, clears the line fairly easily. Yeah! Just goes to show you, always try everything, and never assume anything. I thought for sure there would be no way that bigger cable would clear the line.
    Re: The K-3800 saved the day.
    I have always said have to have the right machine for the right job. That is why I too have sectionals and drum machines on my truck. My preferred first choice machines is the drum machines. But in some cases I can see a sectional would be a better choice and use it first.
      I love my K3800 with the sink drum and 5/16 drop head. The snake spin slower and allows the drop head to navigate the bends a lot better than anything else.
      Sent From The StoolBus
      www.appletondrainandsewer.com
      Appleton WI, 54915
      1-920-284-7471
        had a stoppage last week at a condo building. the first floor master has a double lav sink that has a common double san tee buried in the wall. after several tries with my k-50 and drop head bulb cutter. i grabbed my micro reel and saw exactly where the drop was, marked my cable and tried 3 times to hand place the cable/ cutter in the right spot. finally got it and cleared the line
        being only an 1.5'' line, there was no way to keep the camera and 5/8'' cable in the drain to watch.
        would have been nice to have a c/o in the waste or vent stack, but the line is buried inside a cabinet with drawers. even the roof vent on the 3 story roof was a no go as the line was common vented with the laundry in the other wall that was ok.
          K-3800.... looks like Ridgid somewhat tried to copy the Spartan 100 without the dolly ???
          Good job clearing the line
            Have an K-375 with 75ft of 3/8S cable. What's the difference between the K-3800 and My machine !
              about 3 times the price for the 3800 and 3 times better.
              commercial build compared to homeowner build.
