Spade Cutters And P Traps
    Re: Spade Cutters And P Traps
    Try a c cutter run machine in reverse if you can't make the trap in forward
      i have plenty of spade cutters. i never use them
      what i do use is the 4 blade cutter and i also steal the blade holder from the spade and install my spiral root saw.
      does't sound like the forum cleaners really use or recommend the spade.
      my go to cutters are the 4 blade, spiral root saw and the rick reverse auger
        I've used the spade cutter with some success on kitchen lines. It does a decent job at scraping and breaking up hardened grease in galv and cast lines and then I just flush with water for a few minutes and it seems to take care of things.... The 4 blade would probably do just as good at that task if not better.
        Ideal Plumbing
          The real question is why this was asked ! Please tell Us!
            Spade cutters work very well in cutting through heavy grease.I have used 4" and 6" to unclog manholes in the past with the 1500 machine.
            But your question was regarding p-traps,sorry I never have ran into whole house traps here in Mississippi.
              I have never seen a 4" or 6" spade cutter
                The last ones, I purchased was in 1999.They are somewhere in the shop.
                Whenever my daughter shows up to visit,I will try to have her post a picture.
                Maybe in a day or two.
                • #23
                  i take my pear shaped double three and pinch it together with my channel locks
                  and put a slight bend in the cable right past the chuck. it seems to work out well for me.as for the pinch it generally opens back up once it bangs its way through the trap.it can be a pain to retrieve if there is roots but just forward and reverse to get it back
                  • #24
                    No matter the blade, a flexible trap leader is your best friend for outside house traps.
                    • #25
                      A customer brought this up as a major problem he was having and I wanted to see if it was an isolated situation or a widespread problem. Sounds like it is somewhat of an isolated issue. Thanks!
                      • #26
                        I don't use spades.
                        I don't see whole house traps.
                        I do see 3" and 4" traps on big floor drains, big floor sinks. but on these I'm working from right close to the trap so it's not much of a problem to get whatever I want through and into the line.
                        • #27
                          If I run into a house trap my 11/16 cable with a 3 inch cutter can get by.
                          Or my drill and eel with a four foot section and 3 inch spiral cutter can hop it very easy too.
                          Rod
                          http://unclognh.com
                          • #28
                            not many house traps...but I use a spring leader and double blade cutters...
                            Derek
