Spade Cutters And P Traps
  • Spade Cutters And P Traps
    Does anyone have trouble navigating a spade cutter (pictured below) through 3” and 4” P traps? Does the cutter get caught in the gap on the hub between the trap weir and the connecting pipe? If so, what do you do to get through the trap?
    Re: Spade Cutters And P Traps
    Can you post a pic of the cutter you are referring to ?
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
      You know I rarely use that cutter..What size 5/8", 7/8" ..Try running in reverse just to get through....Oh I use a special auger for that
        Really.................
          If I'm going through a cast iron trap I usually just use the worm head. Spade can get caught on the trap lip sometimes. Trap leader is always used with spade. Push hard while bumping the clutch forward and then reverse usually does the trick.
            Yep.....
              I use what I call an arrowhead. Shaped just like a spade bit, but two spades 90 degrees from each other, so it has 4 points.
              Not very effective on a clog though, so I made (refining) a head thats better. so far I've jumped 3 out of 4, 4" traps. Turns out the 4th was rotted out on the bottom.
                Where are you guys having to deal with these 3" or 4" traps ? The only place I know of them around here is in this certain trailer park that I service.
                  Here about 8 of 10 home I service have a trap.
                  Of those 8 about 2 have no clean out/bypass so the only way to the main is through the trap
                    What kind of trap ..Whole house trap
                      Yep. Most of the older homes have them.
                      Maine is about 95% older homes.
                      OK... well maybe not 95%, but most of what I deal with is older homes unless they are on septic.
                      Don't take this as fact, but I'm guessing whole house traps where installed here up until the late 1950's.
                        We don't have those.. You figure a good trap leader would get you through it
                          You're spoiled
                          To top it off, you probably even have those crazy outside clean outs I've seen once.
                          Last edited by Gene Bickford; 02-22-2011, 07:37 PM. Reason: you're/your oh well, it's all pretty much the same :)
                            Your spoiled
                            I know... rarely do I get an outside cleanout either
                              I new of 1 whole house trap in my town ..But i cut it out its no problem any more
