My first tampon battle with the K60
  • My first tampon battle with the K60
    Another tuff spot trap door into a low basement. Handyman gave up said call the pro's in
    Grabbed the k60 and down I went. Think this is my first time using the k60
    with a trap door and tampons Used the t-102 funnel auger. It grabbed blobs of tampons and their plastic covers .
    One thing I liked best was the light weight of the k60 made it easy to lift the reel of cable and k60 over head to get it out of the basement and trap door.
    Rod
    http://unclognh.com
    Re: My first tampon battle with the K60
    That looks like a hell hole
      your pullin my string ?
      Sent From The StoolBus
      www.appletondrainandsewer.com
      Appleton WI, 54915
      1-920-284-7471
        EEEEWWWW.....That's gross and great at the same time....how many passes did you make before you got them all? How long did it take ya? Did you enjoy using that K-60...just asking cause you know I can and I am looking into getting a k-60 or the GW RT-66....
        Derek
          trust me the building did not look much better.
          when I pulled up the building look like it was abandoned. on the first floor they were holes in the floor in you could see the basement it was disgusting .
          2 families were living on the second floor place was yucky
          Rod
          http://unclognh.com
            get the k60 my opinion I think it's a better machine.
            took me about an hour to clear all the tampons out . there was tons of them including the plastic applicators.in side main sewer had a bad pitch to it. Took about 15 passes to remove all talons yuck. Outside sewer was much easier about 20 minutes 30 foot run
            Rod
            http://unclognh.com
              took me about an hour to clear all the tampons out . there was tons of home including the plastic applicators.in side main sewer had a bad pitch to it. Took about 15 passes to remove all talons yuck. Outside sewer was much easier about 20 minutes 30 foot run
              15 passes??? how many feet on those passes?? man I am tired just reading about it....
              Derek
                GOOD JOB ! Def. looks like a hell hole..Only an hr?Bet it seemed like 10 hrs..
                  You broke it in good
                    The tampons were jammed up on the inside sewer maybe a 20 foot run of inside sewer tops. This section of sewer took about 15 passes to remove all the tampons.
                    It was like a stuffed 4 inch cast iron tampon sausage 20 feet long Job was not that hard to do just nasty. Outside sewer was a 30 foot run took 3 passes to come back clean.
                    Rod
                    http://unclognh.com
                      ......nassty....thats why i nominated you man...if anything u are dedicated!!!
                      Derek
                        Got to keep the roof over my family's head. Drain cleaning don't make you rich anymore. At least not here
                        Someone told me there was Brown Gold in them hills guess I have to snake deeper.
                        Rod
                        http://unclognh.com
                          I was always told I was fishing for brown trout....it don't make you rich but it does help pay the bills...seems like the people who clean up the mess get rich....
                          Derek
                            My neighbor had service master out and his bill was almost $9,000 cleaning up water from a burst pipe
                            Were in the wrong biz my friend.
                            His home owners insurance paid for it but wow.
                            Rod
                            http://unclognh.com
                              Brown gold maybe, white mice definitely.
