6 Hour jetter job !!!!!!!!!!!
  • 6 Hour jetter job !!!!!!!!!!!
    6 hour jetting job today on a two story 4 unit apt. building. only way to jet was downstream from out side basin.what did we pull out you ask???? how about 8-5 gallon buckets of baby wipes and sanitary napkins!!!landlord found out the sewer was backing up for over 4 months and no one in the building said a damn thing.arms and back are sore but pocket full of money.....rat
    Re: 6 Hour jetter job !!!!!!!!!!!
    time for a cold one.nice pull
      Hi Sewerrat66 great job, did you charge hourly? what was the total cost?
      may I ask the specs of your setup you used...
      machine gpm?
      jetter hose size? (looks like 1/4 inch in the pic)
      jetter tip?
      how many feet was the run?
      why a jetter and not rod to retrieve the wipes?
      did you camera first to see what you were up against?
      thank you for any reply.
        hi dhdc,we billed it out at 6hrs @ $300 per hr.my jetter is a american jetter with 8gpm, 3500 psi, 3/8 hose. i used my warthog head on this job.the run was about 110 feet to the city sewer.no need to camera before hand because line was totally blocked and we could tell what was in line by looking into the basin.here is a pic of my set up..................
        rat
          rat
          How do you like American jetter? I've had them saved in my favorites for awhile, and find myself always going back to their website. I'm pretty sure when we get our first jetter, I'm going to use this company. I absolutely love the small trailer you have, and been looking at these.
            i like the jetter very much.they can build you one with any set up that you want. also with my jetter you only need one man to move it any were you want......rat
              Since you have cold winters like us, do you have to constantly winterize the unit?
                it has a anti freeze tank, so its pretty simple to winterize it. also i keep it in a heated garage.....rat
                  Winters are harsh here would need enclosed trailer. No place to store inside.
                  Then just getting the trailer in on some jobsites would be a hassle not including winter driving.
                  Good job clearing the sewer
                  Rod
                  http://unclognh.com
                    I use RV anti Freeze after every job. I put in 10 gallons in the holding tank then let the pump run till it comes out the hose.
                      ratz. gonna be nosy here. how do you bill for rv af? $35. to $45. there. breid.......
                        Nice little set up Rat66
                        How big is the holding tank on the jetter? 100gallons?
                          I charge a jetter charge so that covers the fuel, and antifreeze.
                            yes it a 100 gallon tank. also rv anti freeze and fuel is built in to price of job.....rat
                              never used my 25 gallon anti freeze tank. might convert it to a diesel tank and then i'll have 50 gal. diesel. or might install a root-x foam injector.
