How big is my jetter hose?
  • How big is my jetter hose?
    Just got 13hp honda motor with a cat pump. Cat literature says the pumps is 4 gpm @ 3500 psi. What size jetter hose should I go with? I plan on having less then 150' of hose.
    Re: How big is my jetter hose?
    4 gpm go with 1/4'' id. no problem.
    3/8'' is good for the spray wand, but too much drag and not as flexable for the size stuff you'll be doing.
    150' will be a good choice, but i would also keep a 50' section for short kitchen lines. much easier to handle unless you have the hose reel close by.
      ben, at 4 gpm, 1/4'' hose has about 4.5# psi pressure drop per foot.
      3/8'' has approx .75# psi per foot at 4 gpm. problem is the stiffness and the weight to pull itself along.
        So are we sticking with the 1/4"?
          So riddle me this batman, why would a company sell a 4gpm/3000 psi jetter with 3/8 hose? Are they seeing something we're not?
            I don't jet much...but I have what would be a j-3000 general wire jetter...same specs as gearjunkie.....mine has the 3/8" hose and it does work you ...with a 1/4" hose what size lines could you expect to clean??
            Derek
              didn't you say the 3/8'' was spray gun hose and not jetter hose?
              3/8'' is next to impossible to navigate 2'' turns the bend radius is 3''.
              4gpm is not that much water or pull.
                Not disagreeing with you, just trying to figure this out. I was actually referring to ridgid selling the kj-3000 with 3/8 hose, not what I bought.
                  ben they also rate that jetter for 8'' pipe
                  if you're doing straight runs, then 3/8'' is fine, but it's too stiff for 2'' pipe and turns. 3/8'' is 5/8'' od. way to big for the 1.5 and 2'' that this machine is going to see.
                  the root ranger is a 1/4'' npt thread. not a 3/8'' thread.
                  they also sell the trap hose that's 1/4'' od.
                  i have everything from 1/8'', 3/16'', 1/4'', 3/8'' and 1/2''. the 1/4'' is the one that your specs will work best.
                  like you like to say "trust me"
                    I trust you....don't know why, but I trust you.
                      I also received a package of 3/8 aqua mole nozzles. Is it beneficial for me to bush them down for 1/4" hose?
                        Another question, why not get the 3/8 hose but only use it for 3" & 4" or would the 1/4" still be better for the bigger pipe?
                          the 3/8'' will have less pressure drop and better for straight runs. also makes a good jumper hose.
                          but at 4gpm, the 1/4'' is fine. why not borrow a length of my 3/8 and test before you buy
                            I agree with Rick. The 1/4" is the way to go. I built my own jetter sytem and I run 4 gpm at 3200 psi. I ran the 3/8" when I first built it, and it was just to hard to handle. It didn't push and pull right. The 1/4" for me cleans 2,3,and 4 with no problem. I also put 300 feet of hose on a reel, so I can keep it all at the truck. My next step is to build a remote valve. Right now, my apprentice and I use our phones (one at reel, and one at cleanout). I could probably get a little more pressure with shorter hose, but I like the setup.
                            "don't put that in your mouth, you don't know where it's been"
                              You got me convinced. 1/4" it is.
