Shower drain buildup
  • Shower drain buildup
    What's the best way to clean the buildup that starts to restrict shower drains?
    One of my calls this morning was for a shower drain that, after removing the grate was almost closed due to buildup. I basically, chiseled off the buildup and sucked it out with my shopvac.
    What method or tools do yo guys use? tools, brushes,chemicals, all of the above?
    Re: Shower drain buildup
    Pretty much the same as you but after wards run the old K-40 through the trap with hot water to be for sure for sure...usually get hair after that....
    Derek
      Just got back from another one!
      must be my day. This one was not as bad though.
      I was thinking of some sort of wire brush (bottle brush type) attached to a drill motor that would clean this stuff up squeeky clean and command more $. Maybe an internal brush like the ones used for cleaning copper before sweating. I'll have to look to see what's available.
        Re: Just got back from another one!
        Could get a a/c coil brush that looks like a cone and cut the handle off and chuck it in your drill and ream in and out through the riser and trap...
        Derek
          I found out the build up usually calcium..Looks like stalagtites..The tile probably needs to be sealed ..Some sealers last for a couple years or more..You'd be surprised of the new tile jobs that are never properly sealed
            http://en.wikipedia.org/wiki/Stalactite
              Originally posted by AssTyme View Post
              Yep that's it..
                i use a 1.5'' brass slip joint 90 tail piece 16'' long. of course a piece of copper tubing will do also. then the shop vac if needed followed by the k-50 with 5/8'' cable and 4 blade cutter.
                the slip joint 90 prevents the tail piece from dropping out of my hands and falling past the drain into the trap.
                a brass flanged tail piece will also work on 2'' drains.
