transmitter
  • transmitter
    http://www.toolup.com/ridgid_16728_r...ule-512hz.aspx
    How deep will this transmitter send out a signal..I need to trace out some lines so I am just going to get a scout and one of these for now..
    Re: transmitter
    I've got a sonde not ridgid but similar...10 foot under concrete was on the money with a scout locator...
    Derek
      Re: transmitter
      Where did you get your sonde???
        Re: transmitter
        Specifications:
        Size: ∅ 0.9375” x 2.92”
        Weight (with AAA alkaline battery): 3.5oz (100g)
        Mounting Threads: ¼” – 20 (see website for optional accessories)
        Operating Frequency: 512Hz
        Frequency Tolerance: ± 30-50ppm (.00005 Hz)
        Current Draw Tolerance: ± .015A
        Recommended Battery: Duracell MX 2400 AAA cells (M3 Ultra) have the highest average Amp-Hours output.
        Operating Range of battery is -4°F to 130°F.
        Battery Life with Duracell M3 Ultra: 3.5 hours at 70°F
        Typical maximum detection range with NaviTrack receiver (varies with ambient noise and interference): In air: 25 ft In cast iron: 15ft
        Typical interference sources: Ductile iron, cast iron, wet salt laden ground.
        "don't put that in your mouth, you don't know where it's been"
          Re: transmitter
          15' in cast iron is really stretching it. plastic and clay are more like it.
          of course the condition of the pipe will dictate the density of the pipe and signal strength.
            Re: transmitter
            Just posting the Specs, Sir, Nothing but the specs.
            P.S. sometimes specs are B.S.
              Re: transmitter
              Right, so do you think I would be able to locate say 10' deep..Were talking mostly cast iron lines with SCOUT locator..And what keeps the sonde from spinning off the adapter..Would you use LOCTITE or similar to not loose the head in the sewer?? Would you push as much as you can and spin the cable only when needed???
                Re: transmitter
                how tuff is that ridgid transmitter?can it take a beating in the sewer? how would you connect it to a 3/4 inch spartan cable? or a flat hand tape.can you tape it onto a cable?....rat
                  Re: transmitter
                  No clue...I don't own a camera but I need to locate some lines ..Figured I would invest in a scout and transmitter ..Then later on I would buy a camera reel and get real
                    Re: transmitter
                    the standard cap that's included is a 1/4'' x 20tpi thread.
                    then they sell the caps that allow it to connect to section and drum ridgid cables.
                    the ridgid and spartan end are very close and a little file will make them fit together.
                      Re: transmitter
                      So would you guess 10' deep is max for a scout to pick up the transmitter? Cast iron pipe.. Can you spin it with the machine to get it further down the line or do you have to push it as to not tear up the transmitter..I am thinking the more you spin the cable the better chances of breaking the transmitter..Again I haven't a clue..
                        Re: transmitter
                        I got my sonde on ebay a few years ago...I wrap duct tape over my sonde about 2 to 3 layers thick...
                        Derek
                          Re: transmitter
                          the 1/4'' x 20 thread is more for a fishtape push rod.
                          the adapters for the cable are for spinning it down.
                          10' will be a decent read and accuracy. gets a littly dicy when you go too deep.
