New K60 owner Ebay Find
  • #31
    Re: New K60 owner Ebay Find
    IMHO if I had both in a basement? I would use the drum till I got board then use the K60 then when I got Board of that Use the drill and eel.
    Rotate and keep them cables fresh If I really got board I would try to make a 100 foot "Zip it" out of PVC like those cheap sink ones just longer and more bad azz. Then When I board of that I would prank call all you guy's
    Rod
    http://unclognh.com
    • #32
      • #33
        In a perfect world the Green Bay Packers would be Super Bowl Champs! Good luck to the Bagers tonight and Marquette tomarrow...Tom
        • #34
          Well The K60 Came in today...It cleaned up real nice...It has not seen much use at all...I turned it on to test it and it ran real well and I even spun a section of cable with it..no problem.. The auction said it came with 2 15' sections of Ridgid C 10...And as I suspected that reel was holding more...There were actually 4 sections in the reel for a total of 60' of cable...One cable was bent a bit but I was able to straighten it out with my hands. I didnt realise C10 was that flexable....I'm real happy with that...Then I called Terry at Allstar Equipment Inc out in Mo. and I purchased 105' of General Pro Flex IC 7/8" Cable and a T150-1 C Cutter and the T111 Spiral Saw and 2 A12 coupling keys.. Terry said the Cable will ship to me on Tues or Wed. of this week...I'm ready for root season.. That Allstar Equipment is a top notch outfit....Respectfully, Tom
