Shop-vac cord on Drain machine
  • Shop-vac cord on Drain machine
    I'd like to see cords on drain machines like shop-vacs. After wrapping cord the plug cilps on the cord. I've put these cords on both my K-50's. A simple thing that saves time.
    Re: Shop-vac cord on Drain machine
    the k-50 should have a gfci plug. the shop vac cord does not.
    on the k-50 i just wind up the cable, a few loops and drop it around the clutch handle.
    although it would be nice to see a 15' cord as that would typically cover me for any indoor drain. showers especially
      A gfci mounted on the motor(going up and down) with a shorter cord is something I'd like to see on the k50
        my general mini rooter has what you're talking about, would there be a concern with ordering a replacement cord from general and putting it on your machine? it has the built in gfci and I Think is ten foot long.
          never really tried this on construction equipment,
          but on mic cables and speaker wires and other music and sound cables, many use
          Velcro Cable Wraps,
          there at most band type music stores, there just a strip of Velcro that has a section of grip on one side and the felt type on the other, some are split so they stay on the cords,
          the picture is just one example of them
            velcro just doesn't last that long in the grubby drain cleaning world......
            But it is cheap and replaceable.
            Seattle Drain Service
              I was wondering if it would stand up in construction type conditions, but it is a possibility in some conditions,
                I was told by a contractor I shouldn't plug a GFI into a GFI. He read it in a contractor magazine? I use a inline GFI when needed, use it on the shop vac too.
                I wrap the cord around the body at the top of the legs. It's about 15ft. and I usually don't need an extension cord.
                  Velcro Cable Wraps,
                  I use velcro wraps on stuff too. Mostly on test meters.
                    interesting about the gfci into another gfci.
                    i would think that's true for permanent outlets in a home. but can't picture it on portable equipment.
                    look at any new hair dryer out there. they all have a gfci built into the cord.
                      I was going to make that same point. And where does everyone use their hair dryers? In the bathroom....and what type of outlets are in almost all bathrooms? GFCIs.
                      Ideal Plumbing
                        The GFCI measures the current through the hot wire and compares it to the current in the return wire. If they are the same, all is good. If not, the current is flowing through the chassis of the unit or through your body or some other undesireable path. When this happens, the GFCI opens an internal switch so there is no more power to the plug.
                        It should not affect anything if you plug one or ten GFCIs into each other.
