How Good Are These On Grease....?
  • How Good Are These On Grease....?
    Re: How Good Are These On Grease....?
    Not very good
    Much better
    Rod
    http://unclognh.com
      Originally posted by UnClogNH View Post
      Not very good
      Much better
      Have you had a chance to use them ? What cutter did you use before you had them ?
        I just ordered their 4" one which is actually 3" in diameter. Now I need to find a Spartan to eel adapter.
          this is for my eel and drill with the regular spiral cutter soft plugs and grease were a PITA these make them much easier to clear sludge and grease.
          can you hook up a blade like this? the adaptor is for the ridgid 7/8 you don't need it I was showing DCman different ways to hook up grease cutters to a k60
          You can screw down these types of blades they come flat bottom two without the brass holder
          like the c1 chuck style
          Rod
          http://unclognh.com
            I already have a paddle cutter like the one pictured. I want something that works better
              Crap now I can't find an adapter. I thought AJ Coleman would hook me up but they said they can't
              Might have to get some 1.25" cable now, lol !!!
                Not very good
                Much better
                Part number? awsome looking blades.
                  http://www.electriceel.com/pdfs/mode...hure4-2010.pdf
                    Try electric eel if you see their drum machine The D5 is a drum and has the 1.25 blade adaptor. You can see it at the end of the cable.
                    Rod
                    http://unclognh.com
