Tell Me like it is
    Re: Tell Me like it is
    If the k60 can handle 80% of calls what do you do with the other 20% you can't clear with it?
    Rod
    http://unclognh.com
      20%
        wait..i dont get it
        Derek
          i like the k-50 for its compact size. i can set in into a shower, in a cabinet and ontop of a laundry machine. plus the lower rpm's give me a better feel for the 5/8'' cable.
          sure i'll use the k-60 if it's already out, but if it's just a 5/8'' cable run, then the k-50 is brought out.
          i use the k39 as my drum attachment. don't like the feel of the k-50 drums.
            I hear people saying the k60 won't handle all sewer calls from a good amount of people. If you can't clear it what do you fall back on as a back up if the k60 fails?
            Rod
            http://unclognh.com
              Gotcha..for me it will be the K-7500 but gotta tell you after 25 straight calls not sure I will have to go back for a while...I just wanted to confirm that if I get the 5/8" cable would I need to get the K-50 or can the K-60 work for the same applications...
              Derek
                K-60 has yet to fail.
                • #23
                  Personally, I think the K-50 is the most universal drain machine on the market.
                  From all of the accessories you can buy for it, it's a very strong asset to our industry. (Love the drum attachment)
                  The only complaint I have with the K-50 is the legs...Ridgid needs to re-design that imo. Long over due.
                  • #24
                    Mine hasn't failed me yet..But if it ever does the 1500 comes out..then it's game over
                    • #25
                      Had some the k60 worked great and some it failed and big brothers drill and eel came in to finish. You guys don't just walk away do you?
                      Rod
                      http://unclognh.com
                      • #26
                        Never..Many customers will testify You don't make $$$ walking away
                        • #27
                          Okay so 5/8" cable what cutters do you guys recommend getting?
                          Derek
                          • #28
                            As many different types you can get your hands on.
                            • #29
                              i like the 4 blade cutters and the spiral saws.
                              but the 1 do all that will always get through and open when all else fails is the rick reverse auger
                              • #30
                                Yeah...I knew that was an absolute given....I pulled the trigger and ordered 12 sections of C-8 cable and T-202, T-203, T-206, T-210, T-211, and a couple of A-13, does the 5/8 " cable not have a trap leader??
                                Derek
