K-50 Score
  • K-50 Score
    Scored a this K-50 on ebay. $355, used 2x.
    Now I need cables. What cables do you guys perfer? I'll mostly be doing showers / kitchens and the occasional 3-4" waste line. I was thinking of 60' of each (c-9 and c-8). I also need a A-17 drum adapter and guide hose. If anyone has one they want to sell pm me.
    Once I get this baby tooled up no more drum machines for me .
    Ray
    www.mauiplumbinginc.com
    Re: K-50 Score
    8 sections of standard.
    I have a couple c-9s to boot
    all three sizes of four blade.
    And a drop head...Carefull with using this one.Pin breaks easy
      Re: K-50 Score
      check pm
        Re: K-50 Score
        ray, the c-8 will be your cable of choice for the 2''showers and laundry drains, along with 2'' cleanouts.
        the c-9 heavy duty 10' cable would be a good choice on the 3'' and 4'' lines, but i prefer the 7/8'' and k-60 for the 3'' and 4'' lines.
        the 4 blade cutters are a great all around cutter, and auger is a good one for tight turns.
        don't forget the rick reverse auger for when the going gets tuff. that's the one cable, cutter that gets it done when all else fails
        lets hope that you're k-50 doesn't get lost in the mail. hope it's not shipped by the post office
          Re: K-50 Score
          What Rick said ..Good score on the 50
            Re: K-50 Score
            Rick or anyone else that may have it
            Could you post a pic of differences between the c-8 and c-9 cables?
            Will Rogers Plumbing
            Moore, Oklahoma
            405) 323-2852
            www.willrogersplumbing.com
              Re: K-50 Score
              the c9 is 10' long c8 is 7.5' long. the c-9 is stiffer. otherwise they look the same.
              the c7 is a closed wound cable. stiffer than c8 bit more flexible than C9. i use the c9 or c7 as a leader on floor drains, 2" lines that go to 4" underground, etc.
