Which Drill..........???
  • #31
    Re: Which Drill..........???
    Get the flexible spear head(HDD-2T), HDD-3S, HDD-4S, U-4H, and get the 4 x 6 Expander if you got the cash for the tough root jobs. I never ordered from this site, just linking so you know what I'm talking about. PM me if you get the contact info from who I order through.
    electric eel accessories
    Will Rogers Plumbing
    Moore, Oklahoma
    405) 323-2852
    www.willrogersplumbing.com
    • #32
      I just received a price quote on the cable. Why are the 4' sections almost as much as the 8' ? Are the 4' sections heavy duty ?
      8-DC Eel Cable $43.11 each
      4-DC Eel Cable $39.33 each
      • #33
        Those are pretty good prices on the cable. Eel makes a regular and a heavy duty cable. One has a 1/2" inner core. the other has 5/8". You won't need the heavy duty. I use the regular, and it does more than needed. Just get one 4' section. you won't use it much.
        Moore, Oklahoma
        405) 323-2852
        • #34
          AssTyme Make sure you get at least one four footer their good to have trust me. Learn to feel and listen to your drill and eel that will tell you a lot on whats going on at the business end of the cutter
          Rod
          http://unclognh.com
          • #35
            Received drill today and it's brand new. Chuck key still sealed in plastic and cord never unwrapped. Pleasant surprise
            • #36
              Do you have the cable yet?
              Moore, Oklahoma
              405) 323-2852
              • #37
                Not yet but hope to have soon.
                • #38
                  I am to lazy to re read the thread...were you expecting a used one? If so then good score man!!!
                  Derek
                  • #39
                    Now I'm thinking I should order the Model C with the cable ???
                    Thoughts............???
                    • #40
                      asstyme....but your a drum guy! getting a sectional would be like sticking your foot in your mouth.......it would go against all the hating on sectionals that you have had for the last year.
                      im confused why do you want or need a sectional? your spartan drums can do everything!
                      • #41
                        I would say that is a great idea if you can afford it. The Model C has no computation when it comes to main line drain cleaners. If you do get a Model C, make sure to get the torque wrench Eel sales so you can adjust the clutch on the Model C. They come from the factory set at 100lbs, but I run them at 150bls 90% of the time.
                        Moore, Oklahoma
                        405) 323-2852
                        • #42
                          JH, he doesn't have a biggun' drum, just the Spartan 300. He thinks the 1065 is too heavy for stairs with only 1 guy (and I agree). I think it's more about convenience for his decision.
                          AT: if you are going to do a lot of work with the eel cable in basements, you may want to consider looking for a used K-1500 or Rothenberger 750. Those machines keep the cable contained while spinning (so long as you use the guide hose) and let you work right at the cleanout like you are used to doing with the drum.
                          • #43
                            You are correct ^^^^^^^^^^^^^
                            This won't be my #1 machine it will only be used on the several tough jobs I get each year. It's also a fact that all the tough root infested 6" lines are in not so nice basements so a little splatter won't hurt.
                            I still think that all you guys that are using a Silly K-60 day in & day out are totally nuts
                            • #44
                              Does the 1500 spin eel cable ? Are you using core or no core cable with your 1500 ?
                              • #45
                                the k-1500 will spin eel cables.
                                asstyme i think your nuts for using a drum day in and day out.
                                we cabled 6 sewers today! all of which were done with the finist all around machine money can buy.....k-60!!
