How To Post Images
See more
See less
Which Drill..........???
  • #46
    Re: Which Drill..........???
    The Model C doesn't sling as much crap around as one might think. I don't go in as much basements as you northerners do, but I have never had a problem if the model c making a mess.
    Will Rogers Plumbing
    Moore, Oklahoma
    405) 323-2852
    www.willrogersplumbing.com
    • #47
      Originally posted by jhplumbing View Post
      the k-1500 will spin eel cables.
      Are most spinning core or no core cables in their 1500 ? How much stress do the core cables put on the 1500 ?
      • #48
        I am using Ridgid C-14 cables (and sometimes C-11 cables). The C-14's are heavy duty (heavy weight) 1.25" cables. The eel cables are not going to stress the 1500 out much.
        The 1500 is a beast. I would say look for a deal on a decent used 1500 or model C and jump on whatever comes up first.
        • #49
          Originally posted by Will Rogers Plumbing View Post
          I would say that is a great idea if you can afford it. The Model C has no computation when it comes to main line drain cleaners. If you do get a Model C, make sure to get the torque wrench Eel sales so you can adjust the clutch on the Model C. They come from the factory set at 100lbs, but I run them at 150bls 90% of the time.
          Hope to be ordering soon, have a part number for this ? Will the standard torque wrench that I already have work for this ?
          • #50
            It might. I will have to see what size it is to be sure though. You will need to order a "Torque Wrench Adapter" from Eel though. It goes on the end of the Model C, then you put the torque wrench to it. The model number is SC-16 and it's around 15-20 bucks.
            Moore, Oklahoma
            405) 323-2852
