Jetter nozzles to buy?
  • Jetter nozzles to buy?
    Re: Jetter nozzles to buy?
    brass at those pressures will get destroyed. the orifice/jets will enlarge with brass.
    on a low volume jetter. i would stick to 3 or 4 rear jets to maximize the power of each jet.
    stay away from a forward jet as you'll loose too much pulling power.
    45 degree jets will clean better, but don't pull as far.
    20-25 degree will pull better, but don't clean as well in the bigger pipe.
      I have just about he same spec as you, i use
      root ranger
      Screwdriver nozzel from the jetteredge
      1/4" warthog
      monster mole from aquamole
        Aquamole makes a great set. I use them on the same spec machine along with a root ranger.
          "Must have" nozzles from Mustang Nozzles Australia...
          http://thejettersedge.com.au/index.p...art=0&limit=50
          1) The Root Rat Nozzle is a popular penetrating nozzle that penetrates deep into the root choke early with it's one front jet and 3 jets behind the nose at 45 degrees and 3 rear jets at 30 degrees.
          2) The Screwdriver Nozzle has been designed to get through the toughest of treeroot blockages. Available as a complete nozzle or as Nozzle only to screw directly onto the hose. This is the Plumbers choice nozzle when attacking anything from heavily tree rooted pipes to breaking up ice.
          3) The Grease Ball Nozzle is a round hardened stainless ball with 8 rear jets and no front jet designed for maximum thrust for long runs. The key to the nozzle is the tighter rear jet angles. It won't get stuck on dislodged pipe as often as a standard nozzle. It will punch through a blockage, quickly releasing the blockage.
          4) The Compressor Invader Nozzle for the quick connect people. It is short and narrow, idea for passing quickly into a tight root blockage....and for finding holes in pipe to escape from
          5) The NEW Sidecutter Nozzle. Release date 30 May 2011..... I am very excited about this nozzle. Will reveal more soon.
          6) Not a nozzle but our NEW Safety Plate. This acts as a guide for the jetter hose with breather holes and prevents the hose turning back on you!
          Regards, Bill
          The definition of Insanity: "Doing the same thing over and over expecting a different result."
          Albert Einstein
            The stainless steal grease ball nozzles are awesome. I had a brass set that came with my very first jetter I bought.
