Guess what this does?
    Re: Guess what this does?
    Jetter hose cleaner.
      It cleans the holes of jetter nozzles. Keep mine. Jetters are for guys that can't use a cable very well. Crazy- a stream of water to clean something-just crazy
        It's for removing nipple rings!
        www.ClinkscalesSeptic.com
          Originally posted by trent2 View Post
          it's for removing nipple rings!
          Bingo !!!
            It is used for dragging or retrieving heavy jetter hoses.
              to clean the threads on the end of a hose to put on a different head?
                Ninja Warrior Ring
                • #23
                  Bill is really leaving us hanging
                  • #24
                    used as a set to rotate jetter hose while in use?
                    • #25
                      Made to clean teflon tape/pipe dope off male threads?
                      Ideal Plumbing
                      • #26
                        opens bottles
                        ps... bill? thought you had a controlled rotation nozzle coming out. whats the status on that?
                        • #27
                          Maybe HE doesn't know what it is (or could be), and he's hoping
                          someone here will come up with a good idea he can run with.
                          It's an invention in need of a purpose.
                          Just kiddin Bill, I'm sure you will tell us when the time is right.
                          • #28
                            Originally posted by Ace Sewer View Post
                            opens bottles
                            Its funny that you say "open bottles" We were going to incorporate a bottle opener as a feature but we kept it simple so it only does one thing ______ ___ ________.
                            The Mustang controlled rotation nozzle?
                            It's proving to be very difficult without using oil. We have a new design that is cheap and simple and only has one bearing, without oil. Warthog's patent is old and questionable as oil has been used to control rotation for many years in other devices.
                            We want to design our nozzle so it does not need to be serviced for at least 12-18 months, like the RR nozzle.
                            We are using another system but it has been put on the backburner until the new range of nozzles have been released next month. It's only been 4 years in the making...on and off!
                            Regards, Bill
                            The definition of Insanity: "Doing the same thing over and over expecting a different result."
                            Albert Einstein
                            • #29
                              it slides over the jetter hose end when not in use on the reel to prevent somone from stealing the hose and unwinding it off the reel. the wire brush locks, bites into the hose. you release the wire brush and remove the lock.
                              • #30
                                I would like one with better time between service; seems like I'm always tearing one down for something. Also, with the oil, rotation speed varies a lot with water temp. I wonder about a friction disk clutch pack, like a motorcyle clutch, with an adjustable spring tension.
