Guess what this does?
  • #31
    Re: Guess what this does?
    I'll finish it this year, I promise!!
    Regards, Bill
    The definition of Insanity: "Doing the same thing over and over expecting a different result."
    Albert Einstein
    • #32
      Originally posted by bill2601 View Post
      It's our new (patent pending) tool.
      First one to guess what it was specifically designed to do, gets one free!
      so what dose it do ?
      Sent From The StoolBus
      www.appletondrainandsewer.com
      Appleton WI, 54915
      1-920-284-7471
      • #33
        Ya, I want to know what this thing does. It's keeping my up at night.
        Ideal Plumbing
        • #34
          Are you sure thats not your avatar keeping you UP at night?
          www.ClinkscalesSeptic.com
          • #35
            That there newfangled device combs rat hair. With the brush extended you insert the head of the rat through the hole and pull it down as far as possible. Then retract the brush so the device slides back off the rat's head without mussing the newly groomed hair. Then you let your freshly coiffed rat loose to make the sewers a little more stylish!
            (You should put a warning on the device to wear good leather gloves in case the rat doesn't like the unfamiliar grooming technique.
            Congrats on the new device. Thanks but I don't want one. I just kill the rats.
            • #36
              Ok, ok post no. 15 guessed correctly! And he is an Aussie
              See a very rough video of it working here.
              http://youtu.be/N9ZoY6JIeAQ
              What size are your tap spindles in the US?
              Would it work for you?
              I have tested this hundreds of times. The spindle in the demo video was old and dirty when I first cleaned it. They come up like new after a few runs through the "Spindeze" spindle cleaner. Once the bonnet and spindle are clean, with the right waterproof grease, the tap works like new.
              Sure, you could use your wire brush to come up with the same outcome....but does it fit neatly in your washer box?
              Your thoughts? All feedback is good feedback, as long as you don't use it for cleaning rats, I'm happy!
              Regards, Bill
              Albert Einstein
              • #37
                Okay we call those faucet or valve stems. They vary in size depending on Manufacturer and application.
                • #38
                  Ours are nearly all the same so it will work well here. What are your most common diameters?
                  Regards, Bill
                  Albert Einstein
                  • #39
                    Hey Bill, I really liked that rat grooming idea. Who knows you might find there's a market for that application.
