It was just shocking I tell ya.
  • It was just shocking I tell ya.
    This is a safety post. Accidents happen when you get stressed or are in a hurry. I have GFI cords and use them as a rule. But yep you guessed it I was in a hurry to complete a job and get to the next one and I just used the nearest cord that was not a GFI with my K-500. I plugged in, sent the 1.25" cable down the cleanout, turned it on! Then placed one hand on the cable, then placed the other and bam! I was doing the chicken! I was froze there could not get my hands to release I was trapped. I could kinda yell and 2 of my guys where running to help me but there where going to touch me and then they would have been in the chain. I got one of my feet to move which broke the circuit I guess and I fell backwards on the ground just lying there. Wow I have been shocked before but nothing like this where I was powerless to do anything. So the point of this thread PLEASE USE GFI'S AND DON"T RUSH IT CAN KILL YOU.
    Seattle Drain Service
    Re: It was just shocking I tell ya.
    The 1500 does not come equipped with a GFI from the factory ?
      The k-500 and km-1500 never had a gfi cord when new neather did the earley k-50 or k-60 before the sp marvin
        Your lucky to walk away. Something we all know about, and so many of us abuses this issue. Nothing to play around with.
        Will Rogers Plumbing
        Moore, Oklahoma
        405) 323-2852
        www.willrogersplumbing.com
          This is another service message brought to you by
          Still want do drains for only $50.00 bucks?
          Glad your OK Cuda
          Rod
          http://unclognh.com
            Please go to the hospital asap. A shock like that could mess your heartbeat up at a later time even though you feel fine. Thank you for the warning.
              and also go to see if you burned any thing in side you cant see
              either take all you non GFI cords off your truck or tape a GFI on the end of the cord
                I 2nd and 3rd that go get checked out! Cuda We don't don't want to lose you buddy.
                Rod
                http://unclognh.com
                  I agree....go get checked out. I'm sure we don't have to tell you to use GFCIs now on, your experience was probably enough to teach you to never ever use a standard cord again.
                  Ideal Plumbing
                    cuda, glad you walked away from it
                    but, honestly, better you than an employee
                    been shocked many times, including all my shocking toys but never as bad as you got it
                      Thanks for the reminder. I will bring it up in our next staff meeting. We have RCD boxes in our trucks and we test & tag on a regular basis but you never know just when a power tool will become faulty!
                      Regards, Bill
                      The definition of Insanity: "Doing the same thing over and over expecting a different result."
                      Albert Einstein
                        Glad to hear your okay...hopeful there won't be a next time...but you can tell your guys that they missed their chance to kick their boss!
                        Derek
                          Cuda, I hope you went straight to A&E to get checked out. Just to jump on the back of all here dont be stupid, look after yourself. Also as Bill said we use RCD's but it is always tempting when you are under pressure to take short cuts. Another timely reminder that life is too short as it is without cutting anymore off it
                            Glad you are okay. Did the shock have anything to do with the replacement switch or motor?
                              Cuda, I'm glad you are ok and would like to echo what a few of the other guys have said about going to the hospital for a check-up... A hard shock can actually alter your blood chemistry and get ya sick, a plumber buddy was servicing an air compressor on a sprinkler system back when I was in the military, he got hit pretty hard. 4 days after the shock he ended up in the hospital for a few days until they could get the electrolite levels in his blood back to safe levels... Bill
