Finally have my own jetter!!
  • Finally have my own jetter!!
      Re: Finally have my own jetter!!
      Remember to keep the camera in front of the RR or it will blow out the seal behind the sapphire crystal lens. Then you get fogging behind the lens. But..... there is an answer, Ridgid will exchange the damaged camera head. I've done it many times.
      Regards, Bill
      The definition of Insanity: "Doing the same thing over and over expecting a different result."
      Albert Einstein
          We duct tape the curved section on the front of the RR into the pushrod of the camera at the base of the spring so it locks in together. Tape it up good and check it every 15 minutes. It makes cleaning a long drain line full of roots very quick. You find the roots, go past them, twist the hose and the pushrod together. Pull it back to inspect your work and move on to the next one.
          Regards, Bill
          Albert Einstein
            Great job,
            now that you have the jetting bug, all your going to want to do is jet sewers. i would rather jet than cable!
            From start to finish how long did it take you?
                With a cart jetter the worst part is setup and tear down time. The jetting part is simple
                  great job Ben.
                    what size of jetter hose
                    Sent From The StoolBus
                    www.appletondrainandsewer.com
                    Appleton WI, 54915
                    1-920-284-7471
