rick remote for a big us jetter
    Re: rick remote for a big us jetter
    Speaking of Dan, Rick have you worked out the the root-x injection system for the jetter yet?
    I can't say anything....
      those specs would require a good 27hp engine. don't really need the pressure as i'm not jetting with it.
      i think just enough flow to squirt out the orifice jets. i'm thinking either 5.5 hp gas or 2hp electric.
      the whole purpose of a foaming product is to get the chemical to the top of the pipe. but with a pump spraying the chemical directly in all directions, you don't really need a foam to get it to the top. although the foam would help it cling and stay at the top.
      The foaming agent is separated from the killing agent in the rootX so you can get directly to the active ingredient so as long as you can regulate the chemical feed (I would make a supersaturated liquid from the active ingredient in the rootx) then it just becomes a matter of working out the molarity / exposure per foot of pipe unless you are thinking of making a foam dispenser
        Good job Rick
