liking my K-50 the more I use it
  • liking my K-50 the more I use it
    Getting a better feel for this little maching the more I use it. Mostly Kitchens, laundrys, and laundry room floor drains.
    Had a call this week late afternoon, rental property with backed up tub/lav and owner had worked on for a couple of hours with no sucess. I had kit. sink install nearby so stopped in to take care of. tub was 3/4 full of some nice stuff.
    He saw the K-50 w/drum adaptor and was like "aint never seen nothing like that"
    pulled overflow plate, very old style with small opening, stretched out bulb on 5/16 cable (drum adaptor) to fit,ran down about 8' and woosh! Ran a few more times until no more hair coming out, flushed tub and lav a few times. Was done in about 20 min.
    I like having my hands free to work with cable compared to drill type cleaners.
    Re: liking my K-50 the more I use it
    What does a K50 weigh? Just the machine.
    Thanks.
      I love using the K-50 with the drum.
        machine 37 lbs., drum adaptors 8 lbs 5/16-10 lbs 3/8
          Curious question about those drum adapters. Is the clutch handle still used to spin the drum or.....?
          Ideal Plumbing
            Running 5/16" cable I'll take a 13lb K-39AF. Also does mid & overhead lines with ease.
              Stay out of the sectional discussion Assy, you're such a drum brat!
              The K-50 sits on the ground while the K-39 has to be held in your hands.
              I have both on my truck. The pistol rod collects dust waiting for the 2 or 3 overhead sink or tub lines that I have to rod every year.
              The K-50 is my workhorse.
                I am with AT on this one. The 39af will do it just as well as the 50.
                  Why you gotta hurt my feelings
                    But you have a power feed & never have to touch the cable
                      K-40 sits on the ground and really works well, also no where as heavy as the K-50 plus it has an auto-feed.
                        Sure do miss that "Thanks" button
                          Let's see ..I have a 60 , a 1500, If I got a 50 that would pretty cover all my drain cleaning needs..I mean really what else could you need except jetter...
                            Well over all the years I been cleaning drains and sewers I found sectional machines work well, but they can not get all the lines open. I also learned drum machines work well but again they cannot get all the lines open. One of the reasons why I own both drums and sectional machines. If you want to add a well rounded drum machine get the Spartan 300 with three drums, drum #1 would run 13/32 cable for those real stubborn sink lines, drum #2 would run the 1/2" cable to do the 3" and 4" lines that the 7/8" cables are just not enough to torque up and and get through, and the third and last drum you can load with the 5/8" or .55 magnum cable for the 4" to 6" lines with heavy tree roots. If you do not like Spartan 300 and want to keep it all Ridgid then you need a K-3800 with the 13/32 drum and 1/2" drum and a K-7500 with 3/4" cable. Now you would have all your bases covered.
                            Jetters are a nice addition, but heck my father and grandfather only used truck jetters for the 10" lines and bigger which where the city sewers. They always cabled a line clean, and always offered a 2 year guarantee on the line which stated "one free rodding if the line they rodded blocked within 2 years"
                              a jetter, camera and k-39/45 will cover your needs.
                              don't forget a good plunger. it sees more action than my closet auger and has a 98% success rate.
