We Don't need no Root Ranger
  • We Don't need no Root Ranger
    My Hydraulic jetter motor with root cutting bits came in. Large is 8" med 6" and 4" small for straight runs in pipe. Really storm drains etc. Will have to see but I wanted jetter nozzle options if the Warthogs or 1/2" Root Ranger where taking too long. Specs are 1/2" hose or 3/4" 18-25 GPM 4000 psi.Click image for larger version
Name:	jetter root cutters 2.jpg
ID:	634012Click image for larger version
Name:	jetter root cutters.jpg
    Seattle Drain Service
    Re: We Don't need no Root Ranger
    Now that there is some old school root cutters for a jetter. Key is not to take to big of a bite, or the jetter hose will tie itself into a knot. They do work really well though.
      where did you find those at?
        sort of useless here unless i have a manhole access.
        also those need greasing after every use.
          We had the same trouble, it you don't flood it with oil or grease after every job it will seize up. Great for straight runs, you can really feel it bites into the roots so you have to hang on to the hose. No good for bends in 4" pipes. Great for pit to pit work. They also jam up quickly with roots and have to be removed and cleaned. Here is a picture of a Warthog removing roots from a large culvert using a US Jetter.
          Regards, Bill
          The definition of Insanity: "Doing the same thing over and over expecting a different result."
          Albert Einstein
