Hey JC Looky What I Got.................
  • Hey JC Looky What I Got.................
    Now don't get too excited because I just bought it for the super flexible 25' 1/4" cable that I'm going to try in my K-45AF for those stubborn 90's
    I'll probably end up twisting it up in a pretzel
    Re: Hey JC Looky What I Got.................
    Oh if I could only afford the nice tools you guys have and learn how to make all of that $$$$.
      AssTyme you going to start charging $49.95 too?
      Rod
      http://unclognh.com
        What size cable are you using that your having trouble going through 90's? What type of pipe and fittings are you cleaning? If you want a great 1/4"x25 ft'r get you a marco cable. 5/16" I like general. Oh and both a small so lets call them smaller and smallest.......
          On 1 1/2" galvanized lines sometimes my 1/4" or 5/16" cables won't make the turn on those stubby little 90's.
            You know better than that
              I know lol, I could not help it.
              Rod
              http://unclognh.com
                Holy crap..gotta admit I don't have one of those
                  I can get those with a 5/8 " cable..Ooops never mind ..I don't want the cat getting outta the bag..It's a secret
                    It's kind of surprising how many times I've shown up to do a job and the fixture is half took apart and there is one of those laying there, or the one with the bent tube u-crank-it handle. I did one where I swear there was $50 worth of do it ur-self crap and empty draino bottles laying there.
                      Can't lie to you.
                      Made $$$$ many times with nothing more than a Handspinner.
                        my little sink machine "k-40" uses the same cables as the k-45, those 1-1/4 durham 90s can be a pain, so I just bend the tip of my cable at the base of the bulb. rarely have an issue with making corners now.
                          i only use 5/16'' in my k-39.
                          i was told by someone with more smarts than me that the 1/4'' and 5/16'' cable use the same wire gauge. the 1/4'' is tighter wound and therefore it's going to be stiffer.
                          if the 5/16'' can't make it. my 5/8'' reverse auger will
                            The 1/4" marco cable is much more flexible that the general 5/16" innercore.
                              marco typically uses plastic core.
                              a ridgid hollow core cable is very flexible.
