new to the k60
  • #46
    Re: new to the k60
    Bearings again???
    • #47
      Re: new to the k60
      Originally posted by OLD1 View Post
      Bearings again???
      ***NOT A K-60 EXPERT***
      I do know that once I took it apart and put it together with the "clutch alignment tool"...and adjusted the tension on the belt....so far so good....seemed like from the factory they are over-tightening things??
      Derek
      • #48
        Re: new to the k60
        brand new factory bearings are sealed and it takes some time to ruin the grease shield causing the grease to seep out and the water to seep in. so i doubt the bearings could be an issue at this point.
        my money is on the clutch out of alignment. maybe the factory should start including my special clutch alignment tool. considering i can cut them to size faster than the milwaukee electric cutter
        • #49
          Re: new to the k60
          the belt seems fine . the clutch is offset and has a grove on one of the three teeth . I reassembled , aligned etc. the jaws are still offset and overloading motor.
          • #50
            Re: new to the k60
            use my clutch alignment tool and slowly tighten up the clutch while aligning it.
            the clutch has 3 fingers . makes contact on the drive cone and idler cone. for 1 finger to be off, it's actually 2 of the 6 fingers off. this causes the cable to always be stressed inside the machine and the tighter you depress, the harder the machine has to work.
            i'm pretty sure a clutch alignment will solve your problems. also never over loosen the clutch as this would cause it to slip out of alignment.
            sounds like you're going to be up and running on the next post
            • #51
              Re: new to the k60
              • #52
                Re: new to the k60
                i can't enlarge the photo. but the little bit i see, looks bad on the inside of the clutch.
                can you take some better shots and different angles. maybe enlarge it for us.
                • #53
                  Re: new to the k60
                  we have lift off ! it must have shipped misaligned . never having seen one work i missed it . there are deep groves on the inside and out .do i need to replace it ? thank you very much for the fix .
                  • #54
                    Re: new to the k60
                    i will disasembel and shoot more pic.
                    • #55
                      Re: new to the k60
ID:	626134Click image for larger version
ID:	626133Click image for larger version
ID:	626132Click image for larger version
ID:	626131 some pic.
                      • #56
                        Re: new to the k60
                        seems to be working well,but i don't want cone, cable,etc. damage. dose it need to be replaced ?
                        • #57
                          Re: new to the k60
                          the 4th picture is some serious misalignment.
                          i doubt you damaged the drive cone or the idler cone as the clutch is the wear item.
                          i would see if you can get a replacement clutch.
                          call ridgid and ask for brian mitchell. he's the product manager and with any luck he will be reviewing this thread and finding out why there is a rash of clutch issues with new machines.
                          not sure if it's the guys playing with the new machines and loosening them up to the point of misalignment. or the factory not setting them up right from the get go
                          the nice thing is that you should be a pro when it comes to the disassembly and reassembly of the machine. as you can see, it's a pretty simple machine to maintain.
                          call brian and if need be have him review this thread.
                          • #58
                            Re: new to the k60
                            i had never adjusted it before today it worked for 7/8 cable out of the box. I am still a little faster w/ a 1911 field strip but getting faster w/ the k60 . a good learning experience .only a little frustrating .
                            • #59
                              Re: new to the k60
                              Which 1911 do you have?
                              • #60
                                Re: new to the k60
                                colt series 70 ,para ordnance p-14 and p12
