new to the k60
  • #76
    Re: new to the k60
    ends up I have a casting defect new parts on the way. ridgid has bin very helpful .
    • #77
      Re: new to the k60
      Really...how did they or you come to this conclusion..I would be curious to know what part in the casting is bad....thanks!!
      Derek
      • #78
        Re: new to the k60
        wow pipe doc sorry u had so manny problems wit ur K-60 as since I lost my K-7500 a few months ago when my truck was broke into and i cant aford a nother machine thankfully they left my K-60 cause i have been useing the heck out of it
        SMELLS LIKE $$$$$$ TO ME
        • #79
          Re: new to the k60
          Man of all the things to take is a 275 pound boat anchor....strange....
          Derek
          • #80
            Re: new to the k60
ID:	626159 this is the part . I have bin using my 3/8 duracable till the new part shows up. It shipped today.
            sorry to hear about your stolen tools. steeling the way a man feeds his family ,a hanging offense!
            • #81
              Re: new to the k60
              [ATTACH=CONFIG]15261[/ATTACH] this is the part . I have bin using my 3/8 duracable till the new part shows up. It shipped today.
              I would still like to know how it was determined something was wrong with that part...and what was wrong with it as well...
              Derek
              • #82
                Re: new to the k60
                i figured it out . as shown in the pics the casting is off center.
                • #83
                  Re: new to the k60
                  [ATTACH=CONFIG]15240[/ATTACH][ATTACH=CONFIG]15237[/ATTACH][ATTACH=CONFIG]15238[/ATTACH][ATTACH=CONFIG]15239[/ATTACH]I think i figured out my problem! the idler cone & bearing are not centered in the housing.causing the clutch bracket to hit the housing under load.the spacing between the bearing and housing lower right is about3/16 and upper left is 0 . one can see the marks in the pics.
                  this shows it very well.
                  • #84
                    Re: new to the k60
                    Okay...it took me a minute to see what you were talking about...This makes me want to check mine out..thanks so much for keeping up with this issue....
                    Derek
                    • #85
                      Re: new to the k60
                      got my part today ,all back together ( a very easy to work on) ready to work . I have a 2" cast F D in a boiler room has plastic caps wire ETC... I got it to drain w/ the 3/8 but couldnt get through .so sent the micro drain down and found all the junk. it is so nice to know what you are dealing with. i thought i might start w/ a t-101 see what i can pull back?
                      • #86
                        Re: new to the k60
                        Just a follow-up, guys.
                        The front housing is a cast piece. the mold is two pieces. When the two pieces come together, there is always some slight misalignment between the two. Usually it is so small you don't notice it.
                        In this particular case, there was enough misalignment that it allowed the triangular spring on the clutch jaw to rub against the inside of the housing and get misaligned. This increased the torque and caused things to bind.
                        Pipe Doc, thank you for being so patient and understanding. When end users like you take the time to help us figure out not just which part has an issue but what the issue is and why it happened, everybody is better off.
                        Now that we understand the issue, our plant can work with the casting supplier and try to prevent this from happening again.
                        • #87
                          Re: new to the k60
                          Originally posted by TheMaster
                          I would like to see a video of a sludged up K-sink line being cleaned from inside with the K-60 by taking the trap off. If you can or anyone else maybe could post a link to it. In a real home. I think it would be informative.
                          I'll tell you what I learned after I tried out a K50 with 5/8" open wound;
                          That open wound cable knocks sludge in the arse, often in one pass. There isn't all the working of a 3/8 or 13/32 cable in and out to break up sludge, run that 5/8 in let it spin and feed it a little water and presto. Run some water on the spinning cable and it cleans up very easily. It great for high rise units with long sludgy fountain and coffee sink lines too.
                          I ran a Spartan 100 with 13/32 for 20 years, I scoffed at open wound, for the reasons your siting, then I tried one just for the heck of it and I'm sold.
                          I'm sold on it for sludgy sinks more than I am for sewers.
                          • #88
                            Re: new to the k60
                            Yep , it's good stuff..Messy but does a great job..I hate to resort to a puney as* cable for any drain
                            • #89
                              Re: new to the k60
                              Oh yeah sometimes when you do drain cleaning you get dirty..especially when you do it right
                              • #90
                                Re: new to the k60
                                I dont care if you get dirty,its all about the customer.
                                option......push a cable back into a sealed drum......or option 2 drag it out the azz end of a machine in 10' pieces and haul it out. DUH.
                                I don't own drum machines because I feel they are not as versatile as a sectional.I use em' indoors and outdoors , on roofs, etc.etc.etc..All day long..Sure it gets messy sometimes but I feel they do a better job..So you're right it's all about the customer
