new jetter
  • new jetter
    After much deliberation, I had decided to go with the Ridgid KJ3100. It looked like a great machine, had it all set to order and then found a jetter on Ebay, a used American Jetter, portable 10gpm 3000psi. I talked with Am.Jetter and by adjusting the unloader valve you can get 8.5 gpm 3500 psi or 7gpm 4000 psi. I will play around with the psi and gpm. It has a 30 gal tank with low water cut off switch. The unit had 3 hrs on it, it looks brand new. It was delivered this afternoon, used it for my first job tonight, and have 4 more lined up. The unit is bulkier than the Ridgid, and takes up more room in the cube van, but it should be worth it. I will be buying a warthog nozzle for roots, getting another reeler for jumper hose, will post pics when set up.
    Re: new jetter
    Boone, great to hear. You're gonna love it. We got our jetters about a month ago and have done 17 jobs so far, it's pretty easy to market. Just talk about it a lot, mention it to everyone you meet or work for, and the jobs will come out of the woodwork. Have fun!
      Re: new jetter
      i'm interested in the 3 different gpm delivery specs. the only way i see going from 10 gpm to 7 gpm is by lowering the rpm's of the engine. or the engine is being put under a higher load and the rpm's are dropping.
      the pump is a positive displacement plunger pump. so it's either bypassing at the higher psi level which is opposite of what it should be doing. or the engine rpm's are dropping due to the increased load from the higher psi. i just can't see a 3 gpm fluctuation
        Re: new jetter
        I have to try it out, but I think with the increased load, by increasing the psi, the gpm will drop.
          Re: new jetter
          I recall a jetter manufacturer at one time had where you can select what PSI and GPM with a knob on the trailer jet. Right now I can not remember the name.
            Re: new jetter
            spartan trailer has that on their larger jetters. but i believe it only lowers the rpm on the engine via a throttle solenoid. thus it will drop the psi and gpm accordingly. it doesn't actually adjust the unloader.
              Re: new jetter
              Yea a 10gpm 3000psi pump is always going to deliver the rated GPM if you drop the rpm's the psi will fall off with the GPM's. But who cares great score boone! The first thing I would do is get ready to play the tip matching game where you buy several sizes of tips to get the most psi you can to dial the machine in to what you need.
              Seattle Drain Service
