Corregated underground pipe with gravel in it!!
  • Corregated underground pipe with gravel in it!!
    Down spout feeds to this junk and let in 3/4" crushed gravel. Try vacuum?, K -375 with
    spear head n water hose. I know I must be gentle not to break underground corrugated. could bring pressure washer and My 1/4" jetter 2700 lbs at 3 gal a minute. Looks like this runs a long ways down a hillside thank You Tool
    Re: Corregated underground pipe with gravel in it!!
    I have jetted those lines. They are mostly filled with mud, and the occasional dead animal.
      your only chance is jetting from below upstream and try to suck out the dirt and rocks.
      a few months back, i cleared a plugged 12'' corrugated line that was 30 years old running uphill 105'.
      the trick is water and running upstream.
