Cable Cages vs Tires............
  • Cable Cages vs Tires............
    I will be ordering around 160' of 1.25" eel cable soon. Are eel cages ok, which brand is preferred ? How many feet are your carrying in each cage ? I would like to possibly carry these in motorcycle tires but how many feet will fit in each tire ? Then there is the rust issue
    Thoughts............
    Re: Cable Cages vs Tires............
    I use one of my old Mustang 5.0 tires. I forget how much I have in there, but it's much nicer to ROLL the cable than carry it.
      40' easily fits into a decent size motorcycle rear tire. the tires can be drilled to allow water drainage. nice thing about tires are they roll. free. and can be dropped without damage. but without holes they will retain water and rust your cables.
        Thinking I will go this route. Like you said they are free, roll and pretty much bullet proof. What size holes and how many are in your tires ? The smallest hole saw I have is 7/8", I'm thinking this will be a good sized breather hole
          OMG.......your buying sectional cables!!! another convert to the power of the sectional!! i knew you would open your eyes one day!! what can the 1-1/4" inncore eel cables do that your almighty 1065 cant do??
          I can fit 56' ft of eel cable in one eel basket
            be real careful with a hole saw. the steel belts will grab your saw and give you a twist.
            holes are based on your use. either 1 hole so you can control the spill while in the standing position. or multiple holes and they drain while rolling. personally i prefer the 1 hole to allow for drainage when i want it to.
              I'm not sure I've never ran a 1065. I'm sure it can do a bit more than my 300
              56' sounds pretty heavy for my liking. I think I'll roll with 40'.
                oohh only a 300...thats kids stuff compared to eel cables.
                  Stifle it
                    I use the Eel cages. High quality. I have 56' in each cage. Tire would work too.
                    Will Rogers Plumbing
                    Moore, Oklahoma
                    405) 323-2852
                    www.willrogersplumbing.com
                      Sounds pretty heavy for my aging azz. Do you know how much one 8' section weighs ?
                        I like the cage reel How many sections are you guys sticking in those tires? I'm sure the tires weigh more than the cage reels?
                        Rod
                        http://unclognh.com
                          Each cage with 56' of 1.25 cable weights probably 65-80 lbs. Not 100% sure, just guessing. I've never weighed them, just know they aren't light.
                          Moore, Oklahoma
                          405) 323-2852
                            cable cages for me
                            most of my work is inside some in basements some not. tires don't work for me. besides there is the beverly hillbillies look with tires. not very professional. i get top dollar. drop clothes everywhere all the way to the job. just me. breid.........................
                              Re: cable cages for me
                              I have Rothenberger cages they are open on both sides which makes filling it a breeze.
