Expanding cutter for Ridgid K60..Are they Available?
  • Expanding cutter for Ridgid K60..Are they Available?
    I am interested in a expanding cutter for my K60..I was thinking 4"x6"...I know Electric Eel makes them but I am not sure if they can be used with a K60 or if there is a adaptor to go from my male end 7/8" ridgid end cable to the Eel cutter...Does anyone know whats out there and where to order? Tom at Magic Touch..
    Re: Expanding cutter for Ridgid K60..Are they Available?
    i've thought about it, but i just don't feel that the k-60 cable and power would be enough to run those big heavy cutters.
    stick to a 4'' cutter and if need be, bend the last few inches with an offset to help whip it around.
      Duracable makes a 3X5 offset blade that I'm pretty sure can be pushed through 4" (but not spun through.
      I am planning to get a few for my 6" lines that I use the K-60 on (as well as to use with my 1.25" cables)
        I second ricks advice
          I don't see the K60 spinning the Eels 4" x 6". 1500 no problem, but the K60 just don't see it.
          Will Rogers Plumbing
          Moore, Oklahoma
          405) 323-2852
          www.willrogersplumbing.com
            I agree, the K-60 doesn't have any balls
              asstyme....pound for pound the k-60 will i work your spartan 300 Guaranteed! can your spartan 300 handle 1.5"- 6" sewer lines??
                300 with a 100 drum will work 1.5"-6" just fine if you know what your doing.
                Moore, Oklahoma
                405) 323-2852
                  THe Spartan 300 we have can do 1ΒΌ" to 6" lines. Just swap out drums as needed.
                    The drain & sewer cleaning gods have spoken^^^^^^^^^^^^^^^^^^
                      This is the second thread today that has devolved into a "drum vs. sectional" debate. enough already.
                      The K-60 and the Spartan 300 will do the same stuff, we get it....sheesh
                        Originally posted by swade plumbing View Post
                        this is the second thread today that has devolved into a "drum vs. Sectional" debate. Enough already.
                        The k-60 and the spartan 300 will do the same stuff, we get it....sheesh
                        thank you so much!!!!!
                        Derek
