1/4" Cable.......
    Re: 1/4" Cable.......
    I use a 1/4 x 50 in my small machine ,it gets more use than any machine I own ,saves me alot of trips to the roof .Mine come from drain-cables direct. http://www.gorlitz.com/pc_combined_r...5F4E86B8FE7542
      the general IC 1/4" has the "flexcore" wire innercore, which makes it stiffer than a 5/16" Ridgid IC cable. I find that the combination of smaller cable and slightly stiffer yet still flexible does the trick. also does not kink as easy as the ridgid 1/4" ic cable
        Electric Eel or General has the best 1/4" cable. I don't use the Super-Vee or hand crank auger as much anymore though since I got the Model N. Finding it's 5/8" IC sectional cable will do pretty much any drain under 3".
        Will Rogers Plumbing
        Moore, Oklahoma
        405) 323-2852
        www.willrogersplumbing.com
          Here is some clarification on the RIDGID cable offerings:
          There are 3 different wire sizes of 1/4" cable:
          1/4" cable used in the Kwik-Spin uses a 0.072" diameter wire and a plastic inner core (not sold as a replacement part)
          1/4" cable used in the Auto-Clean has a 0.080" diameter wire and a plastic inner core (1/4" x 30', cat no 34893)
          1/4" cables as accessories for the K-45 and the K-40 has a 0.092" diameter wire (model no's S-1, S-2, and S-3)
          For the 5/16" cables, there are 2 styles:
          5/16" hollow core uses a 0.080" wire (C-1, C-2, C-21, C-22)
          5/16" inner core cables have a 0.092" wire and inner core of steel wire rope (C-1IC, C-2IC, C-13IC, C-13ICSB, C-23IC)
          Since you said you got the cable from Home Depot, I am guessing it is actually the cable intended for the Auto-Clean (0.080" wire). You can get a 25' S-2 cable (cat no 50652) that is able to transmit more torque to the blockage and is better suited for use with the K-45.
            Originally posted by laidback View Post
            I use a 1/4 x 50 in my small machine ,it gets more use than any machine I own ,saves me alot of trips to the roof .Mine come from drain-cables direct. Drain, Sewer Cleaning Equipment & Machines, Water Jetter, Trenchless Pipe Replacement, Bursting & Video Inspection Equipment by Professional
            The two 1/4" x 25' cables I bought from DCD were very stiff.
              "5/16" hollow core uses a 0.080" wire (C-1, C-2, C-21, C-22)"
              "5/16" inner core cables have a 0.092" wire and inner core of steel wire rope (C-1IC, C-2IC, C-13IC, C-13ICSB, C-23IC)"
              Why aren't all these cable options listed on the Ridgid web site "options"/"cables" section for the K-45 & K-40 ?
              Which of the two cables below is more flexible ?
              "1/4" cables as accessories for the K-45 and the K-40 has a 0.092" diameter wire (model no's S-1, S-2, and S-3)"
              ThanX for the info
                That is my experience with dcd 1/4" as well, though I've been using them for some time with few problems (other than they are annoying to get in and out of my machine (gorlitz) as they are so stiff).
                • #23
                  Have any specs on the Ridgid #14013 cable ?
                  • #24
                    I did not find that number in the ridgid catalog. What is it?
                    5/16 inner core works good for me.
                    I found one time I could not get through because of rust build up. I went around a 90 which pushes the cable to the edge of the pipe right into a big chuck of rust.
                    Roots beware of the C snake with shark teeth.
                    • #25
                      I love the Ridgid 5/16" IC cable but it's not good at tight turns.
                      Picture seems to show a plastic inner core but listed as hollow.
                      Ridgid 14013 Replacement Cable for Power Spin
                      • #26
ID:	18227Click image for larger version
                        The Top snake that I use. Not perfect, but does the job most of the time. I don't even have to take the trap apart most times, just spin it through a pop up or pry or drill a basket strainer just enough to get it through.
                        • #27
                          Originally posted by Patrick V View Post
                          [ATTACH=CONFIG]18958[/ATTACH][ATTACH=CONFIG]18959[/ATTACH]
                          You're related to Bob ?
                          • #28
                            ridgid cat no 34893, I think an auto-spin replacement cable, is pretty wimpy.
                            I bought a s2, cat no 50652 a couple days a go to see if I like it. it seems too stiff, much like dcd, though I've yet to use it.
                            I use these just for tubs and showers, so when I say wimpy or stiff, I'm referring to using them in tub traps.
                            • #29
                              how did the marco cable work for you? what is your favorite these days?
                              • #30
                                The Marco 1/4" cables were my #1 choice for small lines/tight corners but they are no longer in business so I've been using a Ridgid 5/16" hollow core cable to take it's place.
                                Not bad but I'm still looking for something a bit more flexible.
