Blades..........
  • Blades..........
    Getting ready to order some different blades and was wondering..... I see there are many without any teeth. How important are they ? I know I have took several of my blades to the grinding wheel and put monster teeth on them trying to make them more aggressive. Are any of you running toothless blades anywhere other than orangeburg ?
    Blades - Duracable Manufacturing Company
    Re: Blades..........
    I have some but they are General Wire brand....they are a lot thicker metal and not flexible at all like the teeth ones....so I don't run them in Orangeburg....that's me though...hope it helps...
    Derek
      all i know is eel makes the best blades in the industry
        And by far the most expensive
          i like the teeth as they tend to be agressive with the roots i cut out. as the teeth wear they become sharper.
          with grease i tend to use the 4 blade cutter or jetter.
          spiral root saw is the cream of the crop on roots. forward they cut and reverse they grab, like an auger.
            I have had the best luck with the HDD-5S, HDD-4S, and HDD-3S and multiple sizes of spear heads. I have many more, but those are what I go to first most of the time.
            http://www.electriceel.com/pdfs/mode...hure4-2010.pdf
            Will Rogers Plumbing
            Moore, Oklahoma
            405) 323-2852
            www.willrogersplumbing.com
              http://www.gorlitz.com/pc_product_de...F79EC334C9AB82 has anyone ever tried one of these,I havent ,just use the standard,spartan type blade holder,just curious//
                it's almost an exact copy to the ridgid expanding cutter. problem i see is it's a 3/4'' wide blade while the ridgid is a 1'' wide heavy duty blade i've had for years and i can keep on grinding mine.
                i believe it's a new product for gorlitz as i don't ever recall seeing it.
                  bad link to website.
                  Works for me it's the "Gorlitz's E 23 expandable blade chuck".
