How to clean plugged jetter nozzles?
  • How to clean plugged jetter nozzles?
    4 or 5 of my jetter nozzles have several ports stopped up and become ineffective. I've tried clearing them with my acetylene tip tool but the ports are too small. What are you all using?
    Re: How to clean plugged jetter nozzles?
    I was going to suggest the acetelyne cleaner but maybe you could try cutting 1 bristle off a wire brush?
      Originally posted by TheMaster
      Try a pilot orfice drill set.
      Haven't seen one of those in years but aren't they also too big?
        Ha! that's exactly what I thought of too. I tried it and the wire broke off in the nozzle. Ruined a perfectly good nozzle.
          sewing needle.
            bill, are your nozzles stainless steel?
            problem with smal jetters are small nozzle orfices. they plug easy and unless you clean them sooner than later, they will cause your jetter nozzle to steer sideways. wearing badly.
            the welding supply will have a pin vise that also comes with minature drill bits. try that.
            also see if you know a jeweler with an ultrasonic cleaner. the hi frequency cleaner might just break down the grit.
            hope you didn't ruin your screwdriver nozzle joey hand delivered to you
              I've had good luck with the orifice drill bits like themaster suggested. just take the nozzles in to your local hvac supplier and ask for help getting the appropriate size.
                Aqua Mole sells a great cleaner for the nozzles. Aqua Mole Technologies Inc. - Sewer & Drain Cleaning High Pressure Water Nozzle Accessories third one down.
                  do you use those much themaster? i've not bought the set because i've never needed them, I just have one of the bits the size of the orifice on my jetter nozzle.
                    BINGO, ULTRASONIC CLEANER !! Thanks Rick . I'm dropping off 2 of My Hand Guns at the pistol range . Also My Little 1/4"
                    jetter jets ! They have one of those Ultra sonic cleaners for Pistols !
                      root canal files... i like .035's
                      they are the same thing aquamole sells
                      Ask yr dentist to save used ones for you. I've gotten them from dentist offices where I'm working. Or an online dental supply; some will sell to non dentists, some will not.
                        harbor freight $4.99 for 5 mini drills and the pin vise.
                        if you need one bill, i just picked up a set today
                        Mini Drill 6 Piece Precision Drill Set
                          When my Aquamole's become plugged I use a fishing hook woks great!
                          Rod
                          http://unclognh.com
                            RIDGID offers a H-21 Nozzle Cleaning Tool. It comes standard with all of our jetters. It has 12 cleaning tips ranging from drill size #49 (.073") to #75 (.021"). The catalog number is 47542.
                            I'm suprised nobody else mentioned this. I would have guessed almost all of you would have this, or at least something similar. The list price is only $14.50, so it's not like we're talking about a lot of money. I certainly don't use it after every jet job, but I do clean the nozzles out whenever I think about it.
