Model C.....
  • #46
    Re: Model C.....
    I will be ordering in the morning. Hope I didn't forget anything.
    1 - # 3101400
    6 - # 8DC
    1 - # 4DC
    1 - # SC-12
    1 - # SC-16
    1 - # SC-1
    1 - # HDD-3S
    1 - # HDD-5S
    • #47
      Re: Model C.....
      So your only getting (6) 8' sections? And (1) 4' section? That's only 52'. Your gonna want more cable than that.
      SC-14A is the part you will want to hook it up to your Drill. That's the only part you will need. Should be around 20 bucks.
      3101400-What is this?
      Will Rogers Plumbing
      Moore, Oklahoma
      405) 323-2852
      www.willrogersplumbing.com
      • #48
        Re: Model C.....
        I thought SC-12 was the shaft that hooks the drill to the cable ?
        3101400 is the Model C kit that comes with 13 8' sections of cable and a cutter package.
        • #49
          Re: Model C.....
          After looking at this looks like I need SC-10 too ? I already faxed my order in :/
          http://www.electriceel.com/pdfs/MODCDCM.PDF
          • #50
            Re: Model C.....
            I just talked to a guy at industromart. He says there is no SC14A. He says I would need SC-10 & SC-12 but by using those two parts it would be a death wish as they could easily come undone unless they were welded together. Does the shaft also need to be cut down to length ?
            I cancelled my order until I get this straightened out
            • #51
              Re: Model C.....
              very simple. just order the front coupling and it's either a 1/2'' drive or 5/8'' drive shaft that fits the coupling.
              get a grade 5- 1/2'' or 5/8'' bolt approx 4'' long that's not threaded at this spot. so it's going to be approx 6'' long.
              use a grinder to grind/ mill 3 even flats onto the smooth shaft spaced evenly that will allow the drill chuck to grip and not slip. simple task with a mill. but a dremel will also work good.
              insert the smooth end into the coupler and then either weld or pin the bolt shaft to the coupler.
              i did this with my general 4 years ago and it's only a shear pin. has never slipped in the chuck or the shaft.
              whole project time is under 30 minutes with basic tools. 10 minutes with a mill.
              • #52
                Re: Model C.....
                AJ Coleman stocks the "drill adapter" or so I was told by Marvin a few months ago
                • #53
                  Re: Model C.....
                  He sure does, I saw it in the drawer with all the Eel cutters last time I was there. He stocks every type of Eel cable and cutter there is as well. He even has some Eel cutters I never seen in the catalog.
                  • #54
                    Re: Model C.....
                    AJC really needs to beef of their web site with photo's and inventory lists of all they have for us guy's who can't get to AJC and see those odd ball thing we would not think of and say OH I need that.
                    Rod
                    http://unclognh.com
