220V Jetter
  • 220V Jetter
    Any recommendations for a 220V Jetter?
    Thanks.
    Re: 220V Jetter
    Buy converters that plug into 220 like dryer and stoves pita but works
    Rod
    http://unclognh.com
      Re: 220V Jetter
      typically you're looking for 3hp. or more wanting 220/240 volts. single or three phase?
      what specs are you looking for? gpm/ psi?
        Re: 220V Jetter
        Low GPM & PSI. Phase? Honestly didn't even think about it.
        Whatever you think.
        Thanks.
          Re: 220V Jetter
          2 hp will put out 1500# at 2.1 gpm.
          most 2 hp are also able to be rewired for 220. single phase.
          specs. psi and gpm will guide you to the unit.
