It's Official....
  • It's Official....
    I'm now a sectional owner & user I know how you guys love pictures so here you be
    Re: It's Official....
    Awesome! POst some pics once you get it all together. What did you end up getting?
    Will Rogers Plumbing
    Moore, Oklahoma
    405) 323-2852
    www.willrogersplumbing.com
      Just got it together and powered it on. Is it normal for you to be able to stop the rotating shaft with your bare hand
      3/4 horsepower unit with 156' of cable and a few extra cutters.
        It's set at 100 lbs of torque. You can adjust it by tightening the two slotted screws on the clutch. Careful though it's super sensitive. Did you get the torque wrench?
        Moore, Oklahoma
        405) 323-2852
          I bought the torque wrench adapter. I already have a torque wrench so hopefully it will work.
          Heading out to the saloon I'll deal with it tomorrow or on the weekend
            Just keep in mind that when you hit a tough blockage you don't want to build up torque like you do with your 300. You will end up damaging your cables. When you hit a tough blockage just put the machine in reverse, go back a few feet then hit the blockage again. Shouldn't take more than a few times and you will get though it. Or just crank up your clutch and go balls to the wall. Either the blockage will give or your cables!
            Moore, Oklahoma
            405) 323-2852
              The only thing I want to know is...who are you going to side with when we have a DRUM v SECTIONAL war?
              Always liked the looks of Electric eel....nice purchase!
                WTF is that thing? Looks like a drill with wheels on steroids
                  unlike your drum machines, never toach the cable when moving with your hand!
                  Will is correct, the torque setting is very sensitive, just a minor adjustment goes a long way. I over tighten my clutch when i first got it and broke 4 cables, thank god for the innercore.
                  Asstyme.......where did you end up getting it from?
                    Can I ask, why you didn't go ridgid ?
                      Home of the finest hand trucks, material handling equipment, Little Giant sump pumps, Electric Eel drain cleaning machine
                        It was between the K-1500 and Eel Model C, I thought long and hard and went with the Eel. If I end up not liking the Model C I can always run the Eeel cables with the 1500
                          As long as a K-Silly isn't involved I'm all good
                            Asstyme, The eel was the better choice
                            Rod
                            http://unclognh.com
                              I see Spartan feed bearings in the picture. If you wore out your feed bearings on the 300 already you are over tightening the feed. The way I do it is I tighten the feed down while the rod is spinning and once it starts to feed just tighten it a half turn more. As for the Eel Model C, you will like it a lot once you get the hang of it. Surprised Marv didn't give you the best price on the setup you got.
