Wall Hung Urinals..........
  • Wall Hung Urinals..........
    After having owned one for over a year with several attempts I can now say that the General urinal auger is absolutely worthless.
    I have actually rodded the last 5 wall hung units with my K-39AF equipped with a Ridgid 5/16" inner core cable. Takes a little to get by the trap but it's better than pulling the damn things.
    Re: Wall Hung Urinals..........
    Uh..yeah...same conclusion I can to...was using the K-40 with a 1/4" cable to run thru the trap...haven't tried it yet but I am going to try the K-50 with the drum adapter and 1/4" cable...the only urinal it didn't work on was a Kohler Dexter Model....gotta pull that one and chemically treat it...
    Derek
      I prefer to go through the trap if at all possible.
      Some are a bear to go through. You could also try Calci-Solv to eat the salts in the drain.
        I've just got a chunk of the 5/16 from my k-40 about 3 foot long, I put a big bend in it about 3" from the end and just chuck it in my cordless drill. Works great if its just salts in the trap. The urinal auger is a pure joke.
          I have never rodded a urinal.....muriatic acid does the trick. Suck the pee out of the urinal with a shop vac and dump the acid in. eats the calcium deposits away.
            Im waiting to try my CT one one
            But if a never work on another one that would be ok too
              Hi! I'm a newbie here. How can I clean my Wall Hung Urinals when it is stained and smelly. Please help!. What should I do. Thanks.!
