Installing a new clutch in a K60
  • Installing a new clutch in a K60
    I decided to put in a new clutch in my K60 yesterday and all went well but I have a question just to make sure I didnt make a mistake...Does the Triangular clutch just kinda float between the housing and the black clip in plastic retainer ?...After install the clutch made a little noise as if it was spinning when I pushed the handle down both in forward and reverse....I did insert 7/8" cable and found that it did turn the cable no problem...Any thoughs appriciated...Respectfully, Tom
    Re: Installing a new clutch in a K60
    Sorry can't help you out on the clutch but didn't you just buy this thing a few months ago ???
      It does in fact float in the housing....to realign just loosen the back clutch nut and slid in a piece of 3/4" copper and re tighten until the pipe is straight and snug...then BAM...your done...
      Derek
        Check out these threads. http://www.ridgidforum.com/forum/t38334/; http://www.ridgidforum.com/forum/t37764-8/
        It isn't about your specific issue, but it talks about using a 3/4" piece of copper tube as a guide to align the clutch jaws as you assemble it.
        If the jaws are not aligned quite right, the big triangle spring can drag on the inside of the housing. It is misaligned too much, it will not transmit enough torque to spin the cable under load.
        The clutch jaw does just float inside, and it shouldn't make any noise when spinning.
          I did just purchase the K60 used off of Ebay back in March...I got it for a steal from a larger tool liquidator...I was looking at the old clutch last week and I saw groves and such in it so I thought since its slow I would put a new one in...But the K60 has performed very well for me...I just didnt want the clutch to go out in the middle of a job....
            Armed with the new information I got from you guys here on the forum I took the K60 apart to find that the black plastic retainer had slipped from the grooves in the housing and was loose...I then realigned the retainer into the grooves on the housing and gave it a twist to tighten it in....The clutch then looked as though it had squared up nicely... I then did the 3/4" copper tube tip which worked well... Thanks to the forum I am up and running..I have a main sewer scheduled for 9 AM tomarrow after which I'll let you know how it worked out...Thanks Tom
              I was having troubles with mine. Then Rick told me about the 3/4 copper 2 foot long special clutch adjuster problem solved
              Rod
              http://unclognh.com
                When to a blocked main sewer call the morning...60' run... roots @ 35'.....K60 performed flawlessly... I love my K60...Tom
                  I went to a blocked main sewer call this morning and took the K60.....60' run.....roots at 35'...The K60 performed flawlessly... I couldnt be happier... Tom at Magic Touch
                    Good deal..everyone with a 60 should carry a 3/4" clutch jaw alignment tool with them
