K75-a
  • K75-a
    What do you guys think of the K75-A? Can you use this unit for root problems? Does this use 5/8 as well as 7/8 cable?
    Re: K75-a
    the 75a looks like a smaller version to the 1500a. but only runs the 7/8'' and 5/8'' cables,
    the k-60 has the same cable specs and takes up 1/3 of the room.
    wait until you find a k-60 as the 75 is not a 1500.
      Re: K75-a
      The k-75 will use 1 1/4 cables if you change the jaws to 1 1/4. The only differance from the k 1500 is the k75 has a 1/2 hp motor and the k1500 has 3/4 hp everything else is the same except the jaws marvin
        Re: K75-a
        Rick is correct....before i had my k-60's i had a k-75 it will handle roots with the 7/8" inncore cables. not a bad machine just big and bulky
