Root ranger review #2
  • Root ranger review #2
    So I've had the ranger now for a few months and wanted to give it another review. I pulled to 90'(1st 50' were ABS, rest was clay) with 1 1/4 bend and 2 1/8 bends, no issues. Getting to 135' took some quick stepping on the pedal but I got there. I've figured to let the ranger go and and twist coming back. When the ranger doesn't want to twist, I let it go in until it can twist and pull while twisting the whole time. From what I saw today, a foward jet isn't always required. The pull is so great it pushes right through the stoppages. I've done 8 jobs since getting the ranger and all were under 60' but this one was at 135 and it took 3 hours, start to finish and that includes location and mapping of the sewer line. Definently happy with the ranger and would buy another one.
    Re: Root ranger review #2
    ben, you still don't trust me
    i know your specs on your jetter/ pressure washer. but fill the others in so they get an idea of the power.
      Oh great will this be the great debate at the party tomorrow? Here I thought it was all going to be about helicopters.
        3.5 gpm 3500 psi
          The root ranger is great, ive had 1 from the start, super powerful and cuts great.
            Will it work on my KJ-2200
              I have had one since they first came out. It works great with my J-3000 which is 3000 PSI by 4 GPM.
                Any truth to thought that they can come unthreaded? Instructions don't mention it.
                Or is everyone now running quick couplers on their RR?
                I am running a KJ-3000 with the RR.
                  if it's screwed on with a crecent wrench, it can't come unscrewd.
                  i purposely don't use quick couplers on anything that ends up in the line. on my hoses and jumpers, all the time. just not in the line.
                    Hello,
                    I have seen in youtube a video where the Rootranger cut an piece of wood.
                    So if it get stucked in a Bench in a PVC drainpipe, is it posible that it make a hole in the pipe ?
                      WE only use quick couplings here in AUST.......
                      NO screwing for us.
                      Never lost a fitting yet
                        The nozzle will only cut through fibrous materials like roots and wood. Shiny surfaces repel the cutting action of the jet stream.
                        But... if you are in a PVC pipe full of sand and the nozzle is left in one position for 4-5min it can sandblast a hole through the side of the pipe. Answer, keep it moving!
                        Originally posted by spanien View Post
                        Hello,
                        Regards, Bill
                        The definition of Insanity: "Doing the same thing over and over expecting a different result."
                        Albert Einstein
                          I doubt you'd get very good performance with the Root Ranger on the KJ-2200. The operating pressure and flow are too small. The nozzle opening is not sized right for it.
                            Super bored today so I set up some clear pvc pipe to observe the ranger in 3" pipe. The pressure cause the hose to bend and allows the nozzle to hit the sidewalls. Only 2 places actually touch the pipe; the tip of the nozzle and the opposite side of the front nose. It blows an area about 1/8 of the pipe surface. Even though the spray coverage is 25 deg, the coverage comes down as as a straight path down the pipe. I placed some tree roots near the end of the pipe and pulled back the ranger. At about 10" the nozzle from the roots, the nozzle starts cutting. 3" from the nozzle is where the spray starts to hit the surface, obviously it seemed to be the most powerful at this point. Since the spray follows the pipe surface, it sheared the roots at the surface of the pipe, the rest of the roots just flopped in the spray.
                            Also interesting is when the nozzle is pointed down, water collects in the pipe. As soon as you turn the nozzle up, the water drains quick, not sure why.
                              Thanks Ben,very descriptive.
